Start to Finish ESL Hybrid - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 22nd April 2010, 02:26 AM   #11
mavric is offline mavric  United States
mavric's Avatar
Default more
more pics.
The only true wisdom is in knowing you know nothing.
A wise man does not need advice and a fool won't take it.
Old 22nd April 2010, 02:43 AM   #12
mavric's Avatar
My wife has a very bad cold/flu/ monthtly thing. I am trying to post everything without other pop in posts as we went along with this project. So please be patient, i will comment on all photos, just hard ti sifer #'s instead of seeing the pic before i post. Just made some short hand notes to help.
Old 22nd April 2010, 02:59 AM   #13
mavric's Avatar
Old 22nd April 2010, 03:27 AM   #14
mavric's Avatar
Old 22nd April 2010, 03:56 AM   #15
mavric's Avatar
the first two do not belong there, the crossover is next.
Old 22nd April 2010, 04:13 AM   #16
mavric's Avatar
TL time
Old 22nd April 2010, 04:29 AM   #17
mavric's Avatar
Last Tl pics tonight. later ,
Built the TV stand today! post that much later, tru=ying to have all pics wihout interuption.
Old 24th April 2010, 12:30 AM   #18
mavric's Avatar
Default Elecronics
Here are some pics of using the coils wired up as we only primarily use 120vac. need 240. It is all soldered then shrink wrapped. There are spacers on the bias to keep from pinching and alow free movement should it need service. which in my case it did, read the diagram wrong and fried a transformer, quadruple check before soldering, saves money and some time, looks better as well.
makes one very pretty panel.
Old 24th April 2010, 12:47 AM   #19
mavric's Avatar
Default Making The Panels
I hope this right, Making the stat frames from idea to reality. There is a rough put together to get the idea and make sure all pieces are cut correct and made to fit. I believe there will be some pics of bracing the corners. Which i did not use, the disign was very rigid and works well.
Old 24th April 2010, 01:33 AM   #20
mavric's Avatar
Default More electronics
Charlie's design, posted on his blog. But here are the or rather the parts list and components, again , i hope have the pics right, doing the best I can.
AMP7 start to finish luka Class D 33 6th June 2011 06:57 AM
Start to a finish. jaudio Chip Amps 18 28th September 2005 12:00 PM
Copyright 1999-2017 diyAudio
