Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 5th April 2010, 08:14 AM   #1
SM7UYJ is offline SM7UYJ  Sweden
SM7UYJ's Avatar
Default How do you measure your coating?
I've been trying different coatings for my ESL's but have had no good way off knowing the "exact" surface resistance.
I have used the method with two coins and a multimeter and I also have a small testpanel to try how the coating works under real conditions.
The time has now come to make a more correct measuring device.
I hopefully will have the opportunity to buy an old Gigameter soon, but until it's on the work bench I would like to build my own DIY-version!
This is what I'm thinking:
1. Probe.
80x80mm Plexiglas with 80x17mm Copper strips 5mm thick.
Gives 1:1.78 W/L
2. DC PSU.
500 or 1000V low current PSU, LM317->NE555->IRF840->diod multipliers.
3. Multimeter. Known internal resistance 10M Ohm
Connect everything in series and measure the voltage over the multimeter.
Will this work, or is there a better/easier way to do it?
/R
The probability of someone watching you is proportional to the stupidity of your action.
- A. Kindsvater
Old 5th April 2010, 12:43 PM   #2
alexberg's Avatar
1. Probe.
Gives 1:1.78 W/L
2. DC PSU.
/R
Per suggestions from this forum frequenters I used simple stencil with slot about 1cm wide + Graphite 33 spray. Draw two strips on coated mylar about 10 cm long and 1 cm apart. Then measure resistance using voltmeter with known input resistance as ampermeter. Metal foil strips did not yeild reliable contacts
Alex
Old 5th April 2010, 08:25 PM   #3
kavermei's Avatar
Send a message via MSN to kavermei
SM7UYJ, I think what you say is good, put some 1kV DC across a piece of foil and measure the current. That's what I'd do.
Kenneth
Never send a human to do a machine's job. --Agent Smith
PCB coating rs1026 Parts 10 2nd December 2011 11:08 PM
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
Diaphragm coating Bazukaz Planars & Exotics 9 15th January 2006 07:27 PM
PCB coating jondavis Parts 3 4th June 2005 10:09 AM
Page generated in 0.08338 seconds (74.16% PHP - 25.84% MySQL) with 10 queries
