Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 23rd April 2011, 12:49 AM   #31
GDJ is offline GDJ  Canada
GDJ's Avatar
Wow.
Simply "WOW!"
Old 23rd April 2011, 01:53 AM   #32
It is amazing as to what you can do with enough determination.
I made those in the winter of 05-06 and then got stupid with a DUI and that set all of my projects back awhile.
I'm not afraid to admit my to mistakes hoping that it will stop some one else from doing the same, As I had learned the hard way !!! jer
Old 23rd April 2011, 02:33 AM   #33
GDJ's Avatar
You and me both. Had to learn by trial and error, and sometimes error and trial......in front of my peers.
Old 23rd April 2011, 02:36 AM   #34
GDJ's Avatar
Hey, speaking of copper mesh, check this stuff out:
Copper Blocker - Lee Valley Tools
This would be plenty fine and open enough for the stators?
Old 23rd April 2011, 02:52 AM   #35
I can't get I good closeup on it.
I might be copper clad.
I wonder what size the holes would be once it is stretched taut?
It is only 5" wide but you never know.
I wanted to try using some rabbit screen material,the galvinized stuff with 1/4" square holes.
I once had source for some that had 1/8" square holes and would be perfect but I can't seem to find it anywhere now. jer
Old 23rd April 2011, 02:56 AM   #36
GDJ's Avatar
It appears to be a tube of copper mesh from the pics, which if it is, would give me a 10" wide swath of loose mesh. It looks pretty fine gauge. Would this pose a problem with the power supplies being too high for the gauge of wire(s)?
Old 23rd April 2011, 03:20 AM   #37
chinsettawong's Avatar
Wow! That takes a lot of time and patience to solder all those rods together.
Wachara C.
Old 23rd April 2011, 03:27 AM   #38
No, The gauge wouldn't be a problem but if the wires are kinky the sharp edges will be a big problem with sharp points causing areas that will arc over very easily.
You want a material that can produce a uniformly flat surface with no sharp edges or points. jer
Old 23rd April 2011, 04:28 AM   #39
GDJ's Avatar
Okay, so theoretically I spread this stuff out, take a flat roller and flatten it. This I can deal with.
Old 23rd April 2011, 05:12 AM   #40
Try it! You will never know unless you do.
I can't say for sure because I don't have A good close up of the material.
But chance are you might have a hard time getting it to be perfectly flat as close tolerances are required.
Typicaly < 5 mil and no more than 10mil over the entire span of flatness to keep the diagphram stable and 15mil is realy pushing it but may be acceptable.
But you never know, so check it out and let us know what you find. jer
DIY Electrostatic speakers Audio Transformer??? pmscompany Planars & Exotics 49 22nd February 2009 03:28 PM
Apogee MPTS-1 speakers for Dummies jpuglise Multi-Way 1 20th February 2008 07:26 PM
DIY Amp fr Dummies? (me) bcycle Solid State 9 20th January 2006 10:12 PM
Finnish DIY electrostatic speakers peranders Multi-Way 1 25th September 2002 07:16 AM
electrostatic speakers junglejuice Planars & Exotics 3 22nd October 2001 09:32 PM
Page generated in 0.10437 seconds (78.27% PHP - 21.73% MySQL) with 11 queries
