Step-up transformer design - Page 25 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 21st June 2012, 02:41 PM   #241
is post239 effectively telling us that a step up transformer driving a highly capacitive load needs to have the few turns of the primary next to the core?
Is it also saying that a thick insulating gap to the core minimises the transformer losses?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 21st June 2012, 02:44 PM   #242
JonasKarud's Avatar
If you have a esl panel with 2.8 nF capacitance between stators, and you drive this panel with a 1:175 step up transformer, then the minimum impedance that the amplifier will see is: (1/6.28x20000x0.0000000028) divided by (175x175) = 0.092 ohm!!
So if you will keep your amplifier in the comfort zone, the max step up must not be higher than 1:53 with your big panels....
Of course, You can put a resistance in series with the transformer for taming the high
resonance peak, but the value of this usally lies around 0.6-0.9 Ohm resulting in a good total minimum impedance of around 2 ohms when using 1:53 step up.
One more thing:There's no reason for building very big panels, as the acoustic impedance load on the membrane will be higher and dampen it's movements.
Old 21st June 2012, 02:57 PM   #243
Legis is offline Legis  Finland
Legis's Avatar
Hi, thanks for the clarification. Yes the impedance will be quite small, the driving amps are luckily quite big (24 power transistors, 120,000µF, 1,5kV trafo and two massive convection elements per mono).
Big stats sound quite good. A line source is ideal when it's from floor to the ceiling. Also the width of the panel has to be something, if one wants to reproduce lower registers. Bass actually sounds very good from a panel, mine go to ~37Hz in my room if driven full range but I will limit the low end response because of the transformers, and handle the middle and low bass with dynamic woofers in dipole line arrays.
Old 21st June 2012, 03:00 PM   #244
Very Good,Legis, it sound just about right I don't for see an issues if the primary is bifilar.
But if it is all possible see if you can have them double up on the insulation layer to the secondary base as this will help tremendously,or as much as they can.
If they use 2 mil material then 10 layers should be good, as an example.
AndrewT, the thicker the insulation the less parasitic capacitance the winding will have.
Even though the core is not connected to anything it still acts like one of the plates of a capacitor and couples each individual turn to form the total residual capacitance of the winding.
I wanted to undo one of my cores and add a thicker layer of insulation to prove this,But I am just not up to dealing with trying to straighten out that much wire and then rewind it again.
At least until I can devise a simple torrid winding hoop of some sorts.
jer
Old 21st June 2012, 03:06 PM   #245
Ahh, Very good Point, Jonas, I didn't stop to calculate the actual impedance of such a large panel.
Most all of the designs that I have been working with have a capacitance of 1/3 to 1/4 or less of those of Legis's.
jer
Old 21st June 2012, 03:20 PM   #246
This maybe redundant, But here is a core that I have been considering on using,
Toroidal Core PN# 140
the also have some bigger ones as well !!!
But very affordable.
jer
Old 21st June 2012, 08:27 PM   #247
JonasKarud's Avatar
Yes, big panels certainly sounds good, but there seems to be an optimum panel widht for high output at low freqs, 8-10 inch for a single membrane, two stator panel and
12-13 inch for a double membrane, three stator panel.
This is my own findings from a long life of building electrostats (and still counting).....
Old 21st June 2012, 09:26 PM   #248
If it were me, I would consider using using 1 or even 3 of the center sections separated from the two end sections as just for the highs.
This would help greatly to reduce the load on the amp.
My little panels are just 3.25" wide and I get at least 45 to 60 degrees of horizontal dispersion for the highest frequency's.
I believe those large panels are already physically sectioned as such by the photos I have seen,so my comment may be irrelevant.
If the stator sections are physically separated from each other, This could easily be done with just a handful of resistors using a segmentation equalizing technique.
This would help with any lobing patterns that you might hear while walking around the room as well.
One of my next builds will be like that as I understand it works very well !!
I sure would like to have a listen to them !!!
Jer
Old 7th March 2013, 05:59 PM   #249
Legis's Avatar
Can I use regular toroidal transformer, with 1:8 step up ratio to drive basic dynamic tweeter load (16ohm compression driver + 200R series resistor). Is the bandwidth enough to reach ultra frequencies without much phase shift? Lets say the primary inductance is for example 166mH. If that kind of trafo is a low pass filter with that load, which kind of transformer should it be? Bifilar wound pri and sec, minimal primary turns...? Should I use a electrostatic shield or not between the pri and sec?
The reason if anyone is wondering, is that I will be current driving the compression drivers, the step up trafo is just to boost the output level back to almost normal. Just a side hobby besides electrostatic speakers.
Thanks!
Old 7th March 2013, 06:32 PM   #250
Legis's Avatar
Actually when I measure the two primaries in series, the inductance reads 166mH, but when the primaries are in parallel the inductance is vanishingly low 0,03mH. Secondary is unshorted in both cases. I quess this kind of primary inductance gives wide bandwidth?
The trafo has 2 x 50 primary turns on a 100VA core (~15-18cm2). If I remember correctly, the primaries are bifilarly wound.
Step Down Transformer Ropie Power Supplies 3 15th October 2006 09:42 AM
Can I use a step-up transformer as step-up? cviller Parts 5 6th September 2006 06:32 PM
help design SE preamp with mosfet buffer and step-up transformer. AudioGeek Solid State 0 19th January 2005 03:02 AM
Help Newbie Design X-over Step-by-Step Kongen Multi-Way 3 21st November 2004 02:32 AM
Using one transformer to step down another. Shoog Solid State 9 28th August 2003 10:00 PM
Copyright ©1999-2017 diyAudio
