| Planars & Exotics ESL's, planars, and alternative technologies |
Hi, i am part way thru designing a magnetic planar woofer like an apogee.
Using the efficiency formulas supplied by linesource, i have come up with a design that i would like to build, however there are a few details i dont understand. How can i calculate the Qes of the speaker when i havent built it yet? So far i have Sd= 0.9M^2 Re= 8 ohms mms= .03Kgs BL=3 The only formula i have found wants Fs as well. How to find Fs in an unbuilt panel?????? Any help appreciated Tony |
#2 |
Hey Baffleman.
You tune the membrane to a certain frequence,you select yourselves wich one. |
#3 |
Bandsei thanks for that, i was hoping to be a bit more "scientific" and try to work out all the thiele small parameters before i buy lots of magnets.
As this is an open baffle, i would like to compensate for the 6db rolloff by making the woofer q=2 , like what carver did with his amazing. Tony |
#4 |
Hey Tony,
I think, what Bandsei meant, you can tension the membrane to any Fs you want. Thus, you can work out what Fs you need if you want a certain Qes. While tensioning, you can measure the membrane's Fs by tapping it. Or by exciting it with an external sound source (function generator+amp+speaker) and checking for maximum response. Kenneth
Never send a human to do a machine's job. --Agent Smith |
#5 | |
Qms is also affected by the structure behind the membrane. The perforation of the plate/sheet holding the magnets will affect damping. Qts=2 seems a fairly low Q for a tensioned membrane. Mechanical part of the damping will mostly be provided by the structure behind. If damping turns out to be too low, a layer of fabric fixed on the rear perforated plate might be a way to go, or chose a plate/sheet with less free area. The right fabric fixed directly on a more open perforated sheet might yield better results (even if it might not look as cool). Kind Regards Last edited by LineArray; 17th February 2010 at 08:45 AM. |
#6 |
thanks to all who answered, some good ideas there.
Linearray i wasn't aware that the magnet structure could influence Qms so much. It appears i have to build a test panel first, to find out all the numbers and then build a "real" panel with the results of the tests. Many thanks Tony Last edited by baffleman; 18th February 2010 at 12:56 AM. Reason: spelling |
#7 | |
I suppose a big planer woofer module already on hand has high Q But true, its very clean and detailed, and misses some of lower midrange/midbass richness I expect it will always be that way And be aware of the so called "drumskin effect" There have been a very innovative and funny one A big plastic film streched out in front of a woofer, with closed air in between Strangely, It actually sounded ok Maybe not 100% correct, but I remember it being very "musical" Back then, I just didnt want to pay the money Well, I also thought it was a bit suspect, at least fore a commercial product But to DIY it, could be fun I wouldnt be surpriced if mr Lyngdorf holds a patent on that one |
#8 |
These Theil/Small equations might be helpful for a paper design you can prototype and measure.
The Large Apogee panel had a Qts varying from 2 - 2.4. Fs ~ 24 Hz. The panel was made out of Kapton, and clamped to a wood perimeter frame. The wood frame had adjustable springs to connect to the exterior cabinet. Adjusting the springs allowed setting the Q, and more importantly, allowed Q variation over the length of the frame to control Q and Fs. This avoids resonance and puts the highest Q near the floor for bass gain and a lower Q on the top area for clarity. The push-pull frame used by Eminent Technology looks like a good design to study. A push pull motor with NdFeB magnets would be worth modeling in FEMM. To validate your work and cost, you can look at AE Speakers 15" Infinite Baffle woofers @ $125 each to compare air volume moved. There are many free tools like the Edge that allow you to model flat frame and H-frame dipoles. You will find people on this forum that stack 3-4 dipole woofers to get monster bass. Vas = 1.4E8 x Cms x Sd^2 Cms = Vas \ (1.4E8 x Sd^2) Sd = the square root of {Vas \ (1.4E8 x Cms)} Fs = 0.159 x the square root of (1000 \ (Mms x Cms)) Mms = 1000 \ (Cms x (Fs \ 0.159)^2) Cms = 1000 \ (Mms x (Fs \ 0.159)^2) no = 9.78E-10 x Vas x (Fs^3 \ Qes) Sensitivity = 112.2 x 10log10 "no"/log10 Rms = ((6.28 x Fs) \ Qms) x (Mms \ 1000) Qes = (6.28E-3 x Mms x Re x Fs) \ Bl^2 Qts = (Qes * Qms) / (Qes + Qms) Vas is in liters Cms is in meters per Newton m/N Sd is in meters squared Mms is in grams Re is in ohms |
#9 |
Here are some details of a planar subwoofer called Infraplanar, designed by Claude Lacroix. Resonance is about 10 Hz.
INFRAPLANAR haut parleur isodynamique plan pour grave INFRAPLANAR : mesurse, écoute ...etc INFRAPLANAR |
#10 |
It gets expencive very fast
I would like to use the superior Rubanoide magnet system, somehow |
| DIY Planar magnetic Hybride | WrineX | Planars & Exotics | 61 | 13th January 2012 07:55 AM |
| I fixed buzz in Sonigistix Monsoon planar magnetic drivers | Andersonix | Planars & Exotics | 19 | 2nd January 2011 07:03 PM |
| ESL vs Planar Magnetic | Borat | Planars & Exotics | 40 | 8th September 2009 02:47 PM |
| WTB: Raidho FTT75 planar magnetic tweeter | luvdunhill | Swap Meet | 9 | 7th December 2008 03:51 PM |
| FS: 1 Pair of Bohlender A1 Planar Magnetic Loudspeakers | dvdvideo | Swap Meet | 0 | 11th May 2005 05:11 AM |
| Page generated in 0.11892 seconds (77.35% PHP - 22.65% MySQL) with 12 queries |
