| Planars & Exotics ESL's, planars, and alternative technologies |
my first attemt of building an ESL is "completed" and tested..and failed. The reciepie is as follows: 1000 X 350 X 2mm perforated, powder coated steel plates, 48% open 6my mylar, Elvamide coated 2mm plastic spacers, epoxied to stators and mylar. (Epoxy sucs, will use cyanoacrylate next time) Power supply: EMCO G60r power module capable of 6kV Transformer: Test 1: 50 Va EI-transformer 2 X 115v primary 2 X 6v sec hooked up in reverse with 2x6 in parallell and 2x115 in series. Test 2: 2 of 50 Va toroid-transformers 1 X 115v primary 2 X 6v sec hooked up in reverse with 2x6 in parallell and 2x115 in series. Both test gave a faint sound. Measured about 25v between the stators. Tried with polarizing voltage negative to diaphragm first, then reversed. Same result, almost no sound. I have no idea what could be wrong, but the dissapointment is huge! Regard (regrets?) bent |
#2 | |
Once you have each of the transformer secondaries putting out 200 Vac, then hook up both transformers together, secondaries in series, all the primaries in parallel. You should still be getting ~ 200 Vac from each of the transformer, and ~400Vac across both. If you get 200Vac across each, but almost nothing across both, swap the polarity on one of the set of transformer primaries. You didn't mention it specifically, so I'll add the comment to hook one end of your HV supply to the diaphragm, and the other end to the center point of your series connected 4 secondaries. Good Luck! |
#3 |
Hi Bentl,
Don't be too pessimistic. Your amp power might not be enough. What kind of amp do you use to drive the ESL? What is the bias voltage you use? About glue, I find contact cement to be extremely good for gluing spacers to the stators. I use thin double sided tape for gluing my diaphragm to the spacer. It works very well for me. If you want to, I can introduce a local transformer maker in Thailand to make a couple of transformers for you. I find their price and quality to be very good. Wachara C. |
#4 |
I´d think the same direction as bolserst and check if prim and sec. windings are wired correctly. If You drive just 1 primary and volume rises it´s one wrong primary, if not interchange one of the secondaries. If its nott the tranny, the source of fail should be found around the bias-supply. A failure of the HV-Bias-supply is unlikely, but the diaphragm connection might not work, so it won´t charge up. Hope You haven´t glued everything together? Because You can test each stator alone before putting everything together. jauu Calvin |
#5 |
Hi, I use a 2x 52w class A tube amplifier
the polarizing voltage should be about 4000 volts I have not tested max yet! Thanks for your replies I will reconfigure the transformers and try again. Regards bent |
#6 |
Hi, I have rewired the transformers and get approx 60X voltage rise on the output.
Applying the polarizing voltage does not affect the sound level, so I guess there is a problem with charging. Either the coating (Elvamide) or the copper foil tape used to electrically connect the diaphragm. I wil buy a better multimeter tomorrow and see if I can measure electric contact on the diaphragm. Regards, Bent |
#7 |
I'll be d@mned!!
After half an hour of faint sound the speaker plays louder and louder....and louder! Seems like it takes some time to charge the diaphragm! Great!! |
#8 | |
congratulations. increase the volume takes the same number and volume decline. your coating 10 * e10 excellent result! ps: next step - direct drive amplifier
Hare Krichna! Hare Rama! Last edited by Kontra; 29th January 2010 at 07:27 PM. |
#9 | |
If so, you might improve the diaphragm charging by running the copper foil the full length(top to bottom) on both left and right sides of the panel. |
#10 | |
the contact appeared to be of great importance and not only when you measure coating resistance. Coins or thick (0.05mm) copper strip do not provide reliable contact, IMO. Sprayed grapfite from aerosol can seems to be much better, just make an appropriate stencil. Another thing to consider: it appeared that corona discharge easily develops at the edges of the contact strip, rendering your measurements quite inaccurate. By the way - have you tried to do scotch test i.e. to see if the coating peels away by Scotch tape? Congratulations, Alex |
| Help! Disappointed with Visaton B200 | Vix | Full Range | 65 | 25th July 2010 10:06 AM |
| ER Audio ESL III Kit, and ESL questions in general | wixy | Planars & Exotics | 12 | 7th December 2007 02:46 AM |
| disappointed in self | eag | Subwoofers | 61 | 14th April 2006 09:05 PM |
| Somewhat disappointed with my Tempests | jonz | Subwoofers | 1 | 17th September 2005 12:51 PM |
| Page generated in 0.13038 seconds (83.61% PHP - 16.39% MySQL) with 11 queries |
