Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 21st December 2009, 04:25 PM   #1
tympani1d's Avatar
Default OT: Aluminum Magnet (Winding) Wire source - retail?
Quick question:
Anyone know of a retail source for aluminum winding (magnet) wire?
I need to make new coils for my Magnepan Tympani 1D's and the 1B bass panels.
23-22awg. I do not yet know what the tweeter wire ga. is.
I may convert to Cu wire but will need to calc. the differences in resistivity and mass so as to not disturb the panel tuning (natural panel freq.).
But, the simplest is of course to replace same with ......
By the way how about a sticky (perm.) thread for our material sources?
Perhaps another for schematics & tech. resources?
Okay...back to lurker mode, and Thank you.
Rejoicings of the Season to All.
Old 21st December 2009, 04:30 PM   #2
kevinkr is online now kevinkr  United States
kevinkr's Avatar
I would post this in the speaker forum - there may even be people there who can help with some of the details needed to do this. I assume you are talking about the actual voice coil conductors on the diaphragms? I'm just wondering how they came to need to be replaced?
www.kta-hifi.net
Old 21st December 2009, 07:37 PM   #3
tympani1d's Avatar
Default What...Why..How Come!
kevinkr: I had "cross posted" there too. But us Tubies seem to have deeper resources and resourcefulness!!
Why -> How come?
The need to replace the voice coils is due to the propensity of these wires to corrode. Almost a guaranteed requirement with these speakers (nothing to do with over driving, etc). If one has had them for more than 15 years... the odds are the coils will be corroded open.The "web" is full of folk who've experienced the need and some who've done the deed!
Just goes to show how one should enjoy what one has because it likely will not be there in the future. I'm just returning to my love of HF audio after 20+ years. These had not seen an amplifier signal in that time. Though they always were there and connected.
References for the curious and unbelieving:
Magnepan Mid/Bass Panel Repair Instructions - DavePride, February 01, 2001 at 17:34:10
Peter Gunn's Magnepan Voice Coil Repair Saga
Magnepan Rebuild
Okay............no more OT stuff over here.... Thank you for your indulgence.
Old 22nd December 2009, 01:21 AM   #4
kevinkr's Avatar
Ouch, I can see why you need to replace the voice coil wiring. I'm wondering whether a polymer varnish insulated copper magnet wire might be better. You could possibly get away with a slightly smaller gauge due to copper's improved conductivity - and this might put you in a region where the added mass is not a big issue. (I'm also thinking the wire is only a small contributor to the overall diaphragm mass, and its effective air load?) Just a thought, possibly I'm all wet..
I guess these older panels are quite different from the 1.4 and 1.6QR I used to own. Mine were quite translucent.
www.kta-hifi.net
Old 22nd December 2009, 04:17 AM   #5
tympani1d's Avatar
Kevinkr: You are thinking rather what Ive been mulling. Though AL magnet wire is avail. in all the same polyamide insulation families, with single, heavy, triple and quad build film thicknesses as well as temperature ratings; the fact remains that without very careful corrosion passivation BEFORE the insulation dip and cure cycles all the insulation coating accomplishes is to trap corrosion. Which as we know is reactivated or accelerates exfoliate grain growth (or other corrosion processes) with current flow and heat emission.
OOOooopps...my aircraft heritage is showing. I used to work in a motor rewind shop (fractional hp up to 5000 hp) too. Longtime ago!!!
Now the likely reason AL wire stock was chosen was for the higher resistance per unit as lower weight per unit....which means lees wire length to achieve the desired 2 ohm per panel. As they are about 150.763 lineal feet of wire in that voice coil.
Anyway, I'm thinking that cross referencing the various resistance / ampacity / cross section area / weight per 1000' charts should give a set of "numbers" to work with. There are 5 doubled wire rows in the center of the panel....kind of like the "kicker" inner coil of many BIG woofers (Hartley, Altec, JBL...et al).. which also serve to bring up the total coil resistance.
One could with fair ease use 2 strands of Cu triple build 200C wire: 1@ 34 awg., and 1@ 29 awg ...........then use 2 additional strands of 34 awg. for the center doubled loops. I think the total weight could be very close.
Just off the cuff scribblings....I still have to dig into the reactance stuff yet. Oh yeah...what you saw was 1 of 8 panels I have to do!!!
My system: Tympani 1D's mid range, Tympani 1B bass panels, custom stand alone Sequerra ribbon tweeters, 4@ Quicksiver 60W 8417 mono blocks (mid & tweeters), Mark Levinson ML-9 (bass), J. Curl Vendetta Research low pass xo, custom passive mid -> treble.
Yes your Maggies did not have the sealer overcoat that my models require.
Remember the Tympani line were actually flagship models marketed under Audo Research Corp. That adhesive- sealant overcoat also is a resonant freq. tuning device to set the panel natural frequency - plus several strategically placed steel bits on the magnet frame to dampen diaphragm excursion.
Golly.... They are going to throw me out of this forum
I did not mean to get this far off topic. Moderator: I you think this needs to be pulled just send me a PM.
I apologize to all, I'll not trespass OT here again.
kevinkr PM me if you'd like... and 6BG6GA if you see this I would really like to talk to you Please PM too!!
Old 22nd December 2009, 03:54 PM   #6
kevinkr's Avatar
I can ask SY or one of the other moderators to move this to a more appropriate venue. (Or merge it with the thread on the speaker forum) I don't think it is too big a deal, but it is definitely way off topic.. I am interested, feel free to PM me if you would like.
Edit: I've emailed SY, hopefully he'll be able to move the thread when he has a spare moment.
This is a worthwhile discussion for anyone who owns older Maggies IMHO. (And I am curious having owned a couple of pairs, although I am no longer in the fold..)
www.kta-hifi.net
Old 22nd December 2009, 04:26 PM   #7
Magura is offline Magura  Denmark
Magura's Avatar
Yeah, you're soaked
Having had to do the math lately, due to a FR driver build, I can trust you the information, that copper can't get even close to aluminum, when it comes to "weight to conductivity" ratio. If the driver is built with aluminum wire, better keep it that way.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 22nd December 2009, 04:53 PM   #8
kevinkr's Avatar
Originally Posted by Magura View Post
Yeah, you're soaked
Magura
That isn't particularly good news, but it is believable. The original wire apparently corroded to death while the system sat unused..
Seems like replacing the voice coils on these things is going to be a huge amount of work.. I think Tympani1D must be a lot more patient than I am..
The end result with some care and good luck should be pretty good for the effort I hope.
I imagine Magnepan still repairs these, but I wonder at just how prohibitive a cost?
www.kta-hifi.net
Old 22nd December 2009, 04:56 PM   #9
Magura's Avatar
But really, just go buy some aluminum magnet wire.
What diameter is the wire in question?
Magura
Old 22nd December 2009, 06:38 PM   #10
tympani1d's Avatar
Magura
Well, really that is exactly what I'm trying to do.
However thus far unable to locate a retail source.
23-22 awg.
kevinkr: Thank you for having the thread moved.
Yes, i could just give Magnepan the money for their wire kits... but I'd much prefer to buy a whole 11lb. spool in case I have several
"senior" moments or similar.
Now if I really knew what I was doing one could simply use 1.5 mil Doculam polyester ("mylar") laminating film, layout the conductor pattern, lay a second sheet (frosted side to frosted side -meaning adhesive sides toward each other) of 1.5 mil (or what ever as there are quite a few grades avail.), make a pair of .010" thick poster board slip sheets. Place the mylar & wire sandwich between the slip sheets and run them through the office type sheet laminator. Permanently sealed.... but then we get to the whole resonant tuning thing. I do not know the diaphragm thickness of that Magnepan used on these. But it can be done I worked with someone who did exactly that when he began annoyed with his stacked Dalquist (spelling?) arrays.
He eventually built 7 foot x 2.250" wide ribbon tweeters that were built into his library book shelves.
Anyway, you folk here have vastly more knowledge than I. So for the moment I'll stick to restoring the Tympani's rather than jumping into drown.
Thank you, all
and
All the finest of the Season.
Aluminum Magnet (Winding) Wire source - retail? tympani1d Planars & Exotics 6 22nd December 2009 09:27 PM
Retail source for xformer enamel? leadbelly Everything Else 1 5th March 2007 05:01 AM
magnet wire (not sure of the term) used as chassis wire? jarthel Parts 8 27th September 2006 09:50 PM
Source for coil winding wire Phil O.son Multi-Way 6 22nd October 2002 02:58 PM
Page generated in 0.13421 seconds (86.57% PHP - 13.43% MySQL) with 11 queries
