Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 13th November 2009, 05:05 AM   #1
Borat is offline Borat  United States
Banned
Default PLUR 2 Evolution
hello it's me again - George Chkhartishvili
that's right boys and girls. i took the most linear ( and dare i say, elegant ? ) ribbon motor design ( my own, if you recall ) :
Plur
and made it MORE LINEAR
behold ! PLUR 2 Evolution
if you refer to the original you will see that the difference is the addition of end caps. these are regular magnetic steel used to build speaker motors.
the result is a DRAMATIC improvement in symmetry resulting in dramatically improved field uniformity.
in fact PLUR 2 Evolution can be optimized for ABSOLUTELY uniform field.
the reason you can see a bit of "noise" in the flux lines on that graph is constructed the outline of the neodymium out of just 3 arcs wit the dimensions optimized by eyeballing the result. i spent about 10 minutes optimizing the shape. the shape can easily be, as i said, easily optimized for ABSOLUTE field uniformity.
once again i encourage those of you who like to build your own ribbons to build a prototype of this, as i don't really have time/money/energy to build one myself at the moment.
ps: this particular simulation is for a motor that will accomodate a 4" wide ribbon for an XMAX of about 10mm. the basic dimensions haven't changed but thanks to greater uniformity now the ribbon can take advantage of the entire width of the neodymium.
thanks for stopping by.
George Chkhartishvili.
Old 13th November 2009, 05:38 AM   #2
Banned
think of an underhung woofer. the reason they are so linear is because the field is controlled on all sides of the voice coil by the gap.
in a regular woofer the parts of the voice coil outside of the gap are hanging in an uncontrolled field which is wildly nonlinear.
similarly in a regular ribbon motor the field is just hanging out there. it couldn't possibly be uniform because it is only being controlled from one side.
here in PLUR 2 Evolution the field is contained on all 4 sides. this is what ulimately enables the uniformity. and this makes it similar to an underhung woofer motor in some philosophical sense. although an underhung woofer doesn't control it on all 4 sides so actually there is no analogue to this design at all.
Old 14th November 2009, 12:33 AM   #3
Banned
Some labels from FEMM in case it's not clear what's going on.
Old 19th November 2009, 03:58 AM   #4
thadman is offline thadman  United States
Very interesting
Aside from the uniform field, wouldn't the steel increase the inductance of such a system, resulting in a smearing of transients and temperature dependent field?
Recall the behavior of the core material in transformers. I believe you will observe air-core transformers to have significantly lower inductance compared to a transformer with a steel core.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 19th November 2009, 04:23 AM   #5
Have you thought of replacing the steel caps with neodymium caps?
I don't think you'd observe the increase in inductance
Plur Borat Planars & Exotics 23 29th December 2010 02:52 PM
Evolution of the Tapped Horn Don Snyder Subwoofers 30 18th August 2010 02:06 PM
PLUR vs Isodynamic Borat Planars & Exotics 4 15th November 2009 05:58 AM
evolution algorithm Jamh Everything Else 0 8th June 2009 06:04 PM
Evolution MK-7 midi keyboard em2006 Instruments and Amps 1 12th September 2008 09:55 PM
Page generated in 0.09042 seconds (78.85% PHP - 21.15% MySQL) with 11 queries
