Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 12th November 2009, 06:23 PM   #11
oshifis is offline oshifis  Hungary
I tried 1% natrium hidroxide (= sodium hydroxid?) with good results. It removes both the photoresist and the aluminium. The material I tried on was aluminized food wrapping foil that I intended to replicate the diaphragm of a pair of orthodynamic headhones. I stuck with the photocpying. I wanted to use the other good side diaphragm as the mask in order to duplicate the faulty side, but the photoresist (Positiv 20) was not evenly distributed on the aluminium surface. It collected in spots like the aluminium were greasy. Perhaps it needed some washing with benzine or whatever so that the photoresist attached better.
Old 12th November 2009, 07:40 PM   #12
Steve Dunlap's Avatar
am planning to try something a bit novel with the mid-range planars --an isobaric planar design where I have to membranes on each side of a center spacer and a sealed space between. That will give me twice the current handling even as it improves the sensitivity by placing each membrane into the higher flux area near the magnets. I don't know of anyone that's tried this before.
Koss did this in their Model 1 electrostatic for the bass panels. They were triple instead of double like you plan.
Old 12th November 2009, 08:15 PM   #13
Originally Posted by Steerpike View Post
Some photoresists use sodium hydroxide as a developer.
This will remove the aluminium - and quite fast too. (I've done it to get clear film from coloured gift-wrap)
yes but be careful -- if you get it on your skin, it won't hurt right away, but it is burning nonetheless.
Old 12th November 2009, 08:18 PM   #14
tinitus is offline tinitus  Europe
Such p-p design with double diaphragms have no advantage
P-P magnet system on the other hand may be very effective, apart from all the drawbacks
Tho, p-p diaphragms with reversed phase converts the dipole into a bipole, which ought to result in more low end, if its big ebough
Or what else might happen in relation to the complete speaker design
But I dont see how two such soft diaphragms which are completely non pistonic will work in unity
At worst they may work against each other, with all sorts of issues following
But please, do build it
And afterwards you will think if only you had used the time, money and effort to perfect an ordinary proven good functioning principle
There is nothing left to invent about this
Old 12th November 2009, 08:31 PM   #15
With ESL's, this can provide more membrane motion for a given set of voltages, which is good because those voltages are limited by various danged bits of reality. As has been pointed out, it was implemented by Henry Kloss briefly. It is currently being used by M-L in their CLX bass panel. You may note that this has never been done for any but bass panels. Anyone care to venture a guess as to why?
With MSL's, I think there should be a similar benefit at least in taking double advantage of the static B field, and as you point out, allowing higher total current density. But as with ESL's, you will find that this arrangement does not work for high and midrange frequencies. The fact that no one is doing this at all may mean something further. Have you done a patent search?
Oop, didn't think about the field interaction between the two membranes. Please don't flog me if it is destructive.
And of course, in any event, p-p is better than single ended, adn your state ment about getting into the stronge part of the field implies single-endedness.
Old 1st December 2009, 03:18 PM   #16
jrubins is offline jrubins  United States
This sounds quite interesting.
Please keep us apprised of your progress
Old 1st December 2009, 05:10 PM   #17
[IMG]Click the image to open in full size.[/IMG]
I have tried a planar with 2 membranes,It can`t be used for midrange but works for bass .Sensivity is not better than with one membrane.
[IMG]httClick the image to open in full size.p://[/IMG]
Old 1st December 2009, 05:24 PM   #18
A push-pull planar woofer would ofcourse have P-P magnet design, and still a single diaphragm/membrane, and gets expencive
Can a mylar rip be repaired? jeffshort2000 Planars & Exotics 6 8th December 2007 01:30 PM
Use of pre-metalized mylar willyCJ Planars & Exotics 4 19th June 2007 08:11 AM
So I got some 6um mylar bigwill Planars & Exotics 7 15th April 2007 11:34 PM
From glass to mylar peterr Tubes / Valves 11 11th November 2003 01:19 PM
1/2 mil Mylar for ESLs phishead8 Planars & Exotics 12 17th December 2001 03:05 AM
Page generated in 0.11225 seconds (82.01% PHP - 17.99% MySQL) with 10 queries
