| Planars & Exotics ESL's, planars, and alternative technologies |
#11 |
Thanks for the info everyone. I looked through the link mentioned above, but I'm not sure that is the original schematic. I believe the schematic at the end of that article describes how to opimize the crossover into 3 sections. I am looking for the original schematic so I can just rebuild the external part of the crossover to its original values for now. Then I will start tweaking
#12 | |
#13 |
Several years ago I had a pair of MGIIIas which I modified the external crossovers for biwiring. When I did that, I recorded all the component values. FWIW, my recorded values differ somewhat from the ones presented above.
For the woofer low pass: 2.9 mH (0.51 Ohm DCR) 250 uF 1.8 mH (0.3 Ohm DCR) For the mid/tweet high pass: 2.2 mH (0.3 Ohm DCR) 60 uF I believe these provide the 300 Hz crossover point. Last edited by Jacques Merde; 9th November 2009 at 12:46 AM. Reason: typos |
#14 |
Here's a schematic:
#15 | |
Of course, going 2-way active will give you better sound, IMO ... but will cost more. ![]() Regards, Andy |
#16 |
I also found my Schematic for the MGIIIa's...sorry it took so long.
Pillage Before You Burn. |
#17 |
Thank you everyone for all of your help. I hope others will find all of this good Maggie MG-IIIa information as helpful as I have.
#18 |
Oops, there's a mistake in the location of C2 in my schematic
The corrected one is attached. Anyway, andyr is right on the money -- an active XO / biamp solution will give the best sound. Good luck, whichever way you go. |
| Ucd and Magneplanar | ecodoppler | Class D | 2 | 2nd December 2008 06:14 PM |
| X250.5 and Magneplanar 20.1 | skidave | Pass Labs | 20 | 6th November 2008 09:39 PM |
| FS: Magneplanar .5QR loudspeakers | sharpi31 | Swap Meet | 0 | 8th July 2007 01:55 PM |
| Magneplanar 3.3 crossover schematic | ecodoppler | Planars & Exotics | 2 | 1st February 2007 03:19 PM |
| Magneplanar ribbon repair? | Ouroboros | Multi-Way | 4 | 22nd January 2004 08:39 AM |
| Page generated in 3.37188 seconds (-84.92% PHP - 184.92% MySQL) with 11 queries |
