Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 2nd November 2009, 08:27 PM   #21
WrineX is offline WrineX  Netherlands
thx alllot for all the info, by the way how do i measure the HV ? have to got an special meter as well? mine is nog rated for that high voltage. i only have an el cheapo multimeter. i will do the breath test. by the way the rods that hold the stator wires is mountes on the pertinax, where of course also the mylar is sticked on, could it be i coated a bit of the partinax? . well after these small tests i try to rip one appart clean it verry verry well and replace the mylar, and tape everything thats not between the stator wires an recoat , so only coating is in the erea used to produce sound. will use the graphite trick allong the spacer (not on the spacer) to spread the HV around vertically like Audiostatic used to do with these panels
By the way anybody has a good idea to remove the old coating from frame if its there in the first place ? its school glue water based and maybe in the worst case some not seen by the eye graphite? not dust.
Old 3rd November 2009, 01:20 AM   #22
chinsettawong's Avatar
Hi WrineX,
I have the impression that you are coating too much glue on your diaphragm. With a good coating material, you should coating your diaphragm with very, very thin layer.
Good luck.
Wachara C.
Old 4th January 2010, 06:14 PM   #23
JonasKarud's Avatar
Hi WrineX,
I missed this thread, are your speakers working ok now?
Old 5th January 2010, 07:19 PM   #24
they are working right now, howeever i have a sensitivity difernece bteween left and right about 2 or 3 dB. and my left mylar tension is a bit to low i gues because it look likes it strikes resonace frequency with verry low bass and tend to flap against the stator. and also the aclaimed 88dB efeciciency is or not true or i cant replicate that result. using the glue. but i did bought a aibrush pistol so im planing of doing the whole thing again, and maybe making a rig for tensioning with weights or some kind (sand bags)
any ideas will still be helpfull
Old 6th January 2010, 10:18 AM   #25
JonasKarud's Avatar
The experienced low sensitivity can depend on a membrane that has too low tension, with a big dip in the 50 to 200 Hz region. I can also tell you that
a friend of mine replaced his AudioStatic 300 membranes with 12 um aluminum coated rescue mylar:
Akla
and is very happy with the sound!
I know that in theory, such a low resistance coating should not sound good,
but it obviously does...
Old 6th January 2010, 07:15 PM   #26
yeah thats why i wanted high resistance, but an audio company in holland has pre coated foil that is not aluminum but foil used for TFT screens, its around the 500 Kohm stil not rally high resistance but pefectly coated, only downside its small so tensionion and glueing is a bit of hard work and its 12 um , wich i consider prerty thick. but maybe ill give it a try , the companye restores them pretty often so i think it should work.
Audiostatic ES 100, mylar replacement audiostaticproject Planars & Exotics 15 25th January 2010 10:13 PM
Help, Audiostatic ES-100 aau70 Planars & Exotics 44 2nd March 2009 10:04 AM
FS: Audiostatic ESL aluminum cross bars bolserst Swap Meet 6 17th November 2008 03:12 PM
Niobium foil-can anyone use it? Spasticteapot Planars & Exotics 15 20th July 2006 07:46 PM
Looking for Ribbon foil SQFan Planars & Exotics 5 14th July 2006 07:43 AM
Page generated in 0.09095 seconds (75.18% PHP - 24.82% MySQL) with 10 queries
