| Planars & Exotics ESL's, planars, and alternative technologies |
#11 |
Hello all,
It has been a while.. Since the last posting i repaired a set of quad esl 's by replacing the membrame from the tweeter panel...and it worked :-) but now it's time for the final 0.3 speakers...but i have 6um and 12um film.. with one should i use ?? Thanks. |
#12 |
although i build my own designs either one would probably work.but through the years of reading most people perfer 6(especialy on tweeter panels) some say that they could could hear a difference imo i would use the thinnest you could get and (i hate to say) if sounds to bright back the treble off a bit.if your only doing one panel i would try to use the same thickness as the other one so that their the same as one might sound brighter due to the lower mass. it has been awhile since i've read any info on them and i dont remember what thicness was used .thin is good as long as they remain stable.i hope that helps. jer
| Series-Tuned Bass Reflex Questions - technical | BAM | Multi-Way | 41 | 31st March 2010 08:46 PM |
| Technical Questions about Digital Setup | fork | Digital Source | 3 | 23rd March 2008 09:12 PM |
| PPI PC2400 technical questions.. | MatthewS | Car Audio | 6 | 26th February 2008 05:10 AM |
| Technical Reviewer | jwatts | Everything Else | 0 | 4th April 2006 05:47 PM |
| technical transmission line questions | BAM | Multi-Way | 13 | 20th June 2005 06:30 AM |
| Page generated in 0.13250 seconds (36.71% PHP - 63.29% MySQL) with 11 queries |
