| Planars & Exotics ESL's, planars, and alternative technologies |
#131 |
Banned
first of all there is no need for any impedance transformation with electrostats as you can simply vary the material thickness to get impedance you want.
secondly you could always just horn load the driver without any pleating. there is just no point in doing it with anything but dynamic drivers which suffer from obesity. |
#132 | |
Seen from the motor you only have load - be it the mass of the "membrane (load)" or the "mass" of air load. Hence it's kinda nonsense to claim "low/high impedance transducer".... ######### Obviously shifting the ratio of membrane mass versus frequency dependent radiating impedance in favour towards zero membrane mass (= which has the same effect as increasing radiating impedance for a given diaphragm mass towards infinity) increases efficiency. *If* the ratio of parasitic mass (membrane) to radiation impedance is already - say 10 times - in favour to air load - there is not much room left for improvement (90% versus 100% to be precise). In the lower department obviously this very ratio isn't any good, thus becoming the Achilles heel of all ELS' (not only - mind you) So - any improvement here will be a biiiig step forward - and as most are aware of – to attach horns that still load in the bass isn't any WAV friendly. IMO above considerations should form the guide line for any new ESAMT prototyping – and as far as I've read, Keith has already understood the direction I'm pointing at. ########### Pretty sure David will come along in a U turn to tell us he " even know better from both experience and arithmetic, but had a brain fart" Electrostatic AMT? ![]() Michael
Audio and Loudspeaker Design Guidelines Last edited by mige0; 8th November 2009 at 10:58 AM. |
#133 | |
Another way to think about it is by imagining operating a loudspeaker in reverse: sound waves impinge on the diaphragm and we consider how well the sound energy is converted into motion of the diaphragm. If the air/diaphragm impedance match is poor (as is typically the case with dynamic woofers, for example) then much of the sound energy is reflected with little induced diaphragm motion. If the impedance match is good (as in the case of an ESL diaphragm) then much of the sound energy can be converted to diaphragm motion and there is less reflection. Notice that all this is equally true even if there's no motor on the diaphragm, which implies there's more to this than coupling the motor to a total air/diaphragm load. Few |
#134 |
Mmhh, no – don't think so, Few.
The two cases, mic versus speaker are fundamentally different in this respect. I would agree though to your arguments *if* you take the challenge to construct a mic with *vacuum* behind the membrane. In this – rather academic – case you are spot on to match the diaphragm's impedance to that of the air so that the waves arriving do not get reflected . In case of a speaker, diaphragm mass is *always* parasitic (as is the spring in the compliance dominated region below F-res) – all that counts is to make the ratio of "air load" veeeeery large with respect to "membrane mass" – something that does not need any "matching" – at least in German we would not associate the term "matching" (balancing) to a sheer optimisation towards infinity. So maybe its semantic? Michael
Audio and Loudspeaker Design Guidelines Last edited by mige0; 9th November 2009 at 05:46 AM. |
#135 |
Few, thanks for that, I was about to mention similar things in a post that I have been working on. I wish I could answer some of the questions being asked here but am constrained by a kindergarten level of acoustics understanding. The bottom line for transducer efficiency is the ammount of acoustic power that can be generated for the electrical power input. In ED transducers such as cones and domes etc around 99% of the input power is used to accelerate the moving mass instead of moving air. With ESL's the power demand is more wattless, meaning the load is reactive. Here the amplifier has to supply increasing current at higher frequencies to charge the capacitances of the ESL.
Somewhat akin to transmission lines air has a characteristic impedance given by p/u. p being pressure and u particle velocity. In a discussion comparing the impedance conditions in the presence of boundaries with that encountered by a freely propagating wave we have to conclude that the impedance is lower away from boundaries. Depending on the units of measurement in use it is 407 mks rayls (acoustic ohms). p in the numerator stays low as there are no containment boundaries to cause a build up and u is high as there are no boundaries to arrest particle motion. Perhaps somewhat counterintuitively for an electrical theory person, when a propagating wave meets a boundary we do not have a short circuit and a low impedance, but the opposite. The pressure increases and the partical velocity tends to zero, thus we have a higher impedance. As in electrical theory, power is not due to E or I alone, but is the product of the two. Also, only the real part of a complex impedance takes power from the generator, the wattless (reactive) part being returned to the generator. Impedance matching is a two sided affair where we can examine the electrical load a transducer presents to the amplifier or the impedance the transducer is presenting to the air. Sadly, with efficiencies of around 1% the radiation impedance gets totally masked by transducer mechanical impedances. Under "radiation impedances" Beranek examines four types of radiator. A pulsating shere A plane circular piston in an infinite baffle A plane circular piston in the end of a long tube A plane circular piston without a baffle The real and imaginary parts of the radiation impedance are plotted in magnitude against ka (acoustic size). If there is a textbook analysis of the pleated membrane I am sure we would all be interested. Perhaps noting the shapes of a quadratic residue diffusor tells us that there is something quite different about pleated shapes compared to flat or curved ones. That difference is likely to be in the acoustic impedance that they present to incident waves. Armed with these kindergarten understandings does at least allow us to question the assertion that a memrane powered by X means has a "perfect" match to the air. This seems to depart from the subject which is about having a radiator where the electrical load has a maximised real part and a minimised imaginary part over the frequency range of interest. The Ronald Wagner book has a chapter by Walker which is quite informative re radiation resistance. In ESL's the dominant loads are the reactances due to stiffness and mass. In the region where these transition from spring to mass we see a real part to the impedance. Walker says "The impedance (Z) may include dissipative terms in the form of absorption and/or acoustic radiation resistance". Let's have three cheers for the dissipative terms, as they are pretty hard to find in most transducers! Keith Last edited by Keith Taylor; 9th November 2009 at 06:04 AM. |
#136 | |
Very nice summary of a big subject. Anyone else who is interested in acoustics would also enjoy deep insights from reading Bernanek (or Olson), regardless of your background. BTW, in terms of the effect on the returned wave, there is correspondence between acoustic waves striking a solid boundary and EM waves striking a conductive surface. FWIW, here is an AMT patent from this decade, where the authors based their invention on 1) the benefits of using a horn to match an AMT's relatively high acoustical impedance to the open air, and 2) the benefits of finding ways of providing greater uniformity in the field and in the acoustic coupling. They cleverly designed a magnetic and support structure so that it integrates uniform and optimal load matching and simultaneously optimizes field uniformity. They assigned it to Cerwin-Vega (may have been employees of the company), who obviously have a strong interest in efficient transducers. Have not seen a product, yet, although they had apparently a coaxial design on the market long before. Unfortunately, their figures do not include data from their research, but maybe they published a paper. |
#137 |
Have you seen US5479061, Keith? Although this invention is meant for fabrication using microelectronics methods, and the scale must be pretty small, it does appear to teach a stator-less dielectric membrane ES AMT. Unfortunately, the pdf is much too big to upload, and it zips to an even bigger file for some reason.
Best route IMO is Patent US5479061 Attached the cover page extracted from the original pdf. Way off topic, but just learned that Gene Czerwinski, first author of the integrated horn AMT patent attached to the previous posting, was the founder of Cerwin-Vega, so I know finally where the company name came from. Last edited by DavidJanszen; 9th November 2009 at 02:59 PM. |
#138 |
David,thanks for the patent links. Czerwinski has written a few AES papers but I did not realise they were into pleated diaphragms. There seems to have been a level of pent up interest at the time of the Heil patent expiry. Yes I had come across the micromachined transducer by searching US patents. Found it pretty hard to take in, but if you read between the lines the references to ES powering means and some kind of a similarity to a pleated structure becomes apparent. If patents are supposed to have a teaching function not certain what this one teaches. Maybe how to use a lot of words without giving too much away.
Keith |
#139 |
#140 |
OK, I've had a bit of time to think on servoless centering
for the half baked wave motion version.... My suggestion about tapering the electrical width of the stators maybe varies the impedance and/or motor strength, but I don't see how it looks or act much like a mechanical spring. Got a new half baked idea: Supposin we were to curve both stator surfaces slightly? So's gap inbetween is shortest near the middle of the device. Now the length of a crossing peel varies with the displacement, and subtracts from the overall capacitance stuck to the stators, causing both physical and electrical tensions to rise. Stator capacitance becoming our spring we were needing? |
| Electrostatic Transducer ? | poynton | Planars & Exotics | 0 | 21st January 2008 06:16 PM |
| Using electrostatic CRT's | Simpleton | Parts | 1 | 22nd June 2005 11:08 PM |
| Electrostatic's and Sensitivity | fr0st | Planars & Exotics | 11 | 3rd February 2004 09:27 PM |
| Electrostatic Speakers & Amp | ralph-bway | Multi-Way | 28 | 6th July 2003 07:43 PM |
| Electrostatic Shields | Gumboots | Tubes / Valves | 5 | 21st August 2002 03:48 AM |
| Page generated in 0.14962 seconds (85.79% PHP - 14.21% MySQL) with 11 queries |
