Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 27th October 2009, 07:54 PM   #31
bolserst's Avatar
Originally Posted by arend-jan View Post
The picture you show has the back grill removed. This metal grill originally has a sheet of natural fibre cloth on the inside (attached with a sticky tar like substance to the grill) which damps the main resonance peak of the bass panels.
Arend-jan,
When the grill+damping cloth are in place, do you know what the distance would be between the diaphragm and the damping cloth?
Would you happen to have any pictures of the inside of the back grill showing this cloth?
Thanks for the info.
Old 27th October 2009, 08:31 PM   #32
Hi Bolserst,
The distance between the bass panel and the back grill would be a couple of cm.
Old 2nd November 2009, 02:37 PM   #33
bolserst's Avatar
Originally Posted by bolserst View Post
Previously, I had thought that mounting tightly woven cloth on the inside of the stator closer to the diaphragm would provide better damping than when it was mounted outside the stator. However, I tried this 2 weeks ago, and the LF damping was identical between the two mounting techniques. I did not compare high frequency effects.
Just wanted to add a note about comparison of damping affects with cloth mounted inside the stator .vs. outside the stator. I was looking back over my measurements, and again noted that the damping of the fundamental resonance was the same. However, damping of the higher frequency diaphragm modes was slightly improved with the cloth mounted inside the stator, closer to the diaphragm. Not a huge improvement, but measureable.
Old 11th December 2009, 10:00 PM   #34
Dave is offline Dave  New Zealand
Hi Bolsert,
Do you have any photos of your test set-up of the damping materials?
DIY DAC, 24/192 inputs, fully balanced
http://www.diyaudio.com/forums/showt...hreadid=122078
Old 12th December 2009, 04:44 PM   #35
bolserst's Avatar
Originally Posted by Dave View Post
Hi Bolsert,
I thought I described the setup pretty well in post #25 and #26 where I showed the results.
The testing was done on a panel similar in size and construction to those used by Capaciti and Audiostatic for full range ESLs.
" The ESL panel used for the test was 60" tall x 8" wide "
For the Near Field tests:
" Microphone was placed 1" in front of the midpoint of the diaphragm "
For the Far Field tests:
" Microphone was placed 1 meter in front of the midpoint of the diaphragm "
I'm not sure what additional information pictures would provide, but here are a few of the NF setup:
1) panel with no damping
2) panel with felt on rear stator
3) panel with felt on front stator
4) panel with mesh on rear stator
Hope this helps...
dots or strips for spacers? CharlieM Planars & Exotics 2 23rd June 2008 04:27 AM
FS: Silicon Chip K5600 6-ch vol control janneman Swap Meet 3 22nd July 2007 07:20 PM
Capacitor voltage rating in dots? olev Parts 9 9th July 2007 07:41 AM
Panel resonance control markp Multi-Way 13 11th January 2004 12:45 AM
Page generated in 0.08361 seconds (77.63% PHP - 22.37% MySQL) with 11 queries
