Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 26th September 2009, 05:29 PM   #1
Cyan is offline Cyan  Italy
Default AMT vs. Ribbon
Hi, i'd like to know what you think about the differences between ribbons and amt tweeters.
I want to know about the specific differences, and if you think wich one of the 2 is overall better (if it's possible to say that).
Old 27th September 2009, 06:26 AM   #2
Send a message via ICQ to ackcheng
I remember when I search for AMT vs RAAL before on thus forum. Many prefer RAAL saying that it is more neutral.
Old 27th September 2009, 07:43 AM   #3
Borat is offline Borat  United States
Banned
AMT is a very clever way of packaging the magnetic field around the diaphragm. a ribbon should theoretically be better but require a much more powerful magnetic circuit as well as a transformer.
so i would say that AMT for price/performance and ribbon for cost no object ultimate high end.
but this is just theoretically. i don't have any listening experience here.
Old 27th September 2009, 08:09 AM   #4
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
The open backed AMT's are bipoles whereas an open backed ribbon would be a dipole.
AMT's are in phase front and back I think, unlike most drivers, including ribbons.
Old 27th September 2009, 10:04 AM   #5
Ok, but i find the cheapest amt at 300$. While you the fountek neocd 3.0 can be found for 90$ (it should be an "average" ribbon).
Old 27th September 2009, 10:15 AM   #6
I found them in very top end systems. Are them maybe the best ribbons out there?
Old 27th September 2009, 04:46 PM   #7
This subject has been covered on this forum before. On one audio half cycle the pleats are compressing air on one side of the diaphragm and rarifying it on the other. For the other half cycle (drive voltage sign reversal) the oposite applies. Thus the AMT is no different to a cone etc, making it a dipole when unenclosed.
AMT's and ribbons share one characteristic in that they are acoustically large in the vertical dimension and small in the horizontal dimension. This means they are going to have broader directivity horizontally than vertically. As an AMT can displace more air than a ribbon for the same motion it can be crossed over at a lower frequency for a given SPL. These are theroretical differences, but like most things in audio the final arbiter is the "earometer"
Keith
Old 27th September 2009, 04:57 PM   #8
cuibono is offline cuibono  United States
cuibono's Avatar
Agreed with the above. AMT's also have a higher max power handling and SPL (at least the Beyma TPL-150). AMTs are much less fragile than ribbons. I would note that being able to cross them lower (sometimes much lower) can be very useful if you're concerned about lobing at the crossover and power response.
Old 27th September 2009, 09:01 PM   #9
diyAudio Editor
Variac's Avatar
Thanks for straightening me out Keith
Old 27th September 2009, 10:46 PM   #10
tinitus is offline tinitus  Europe
Two things puzzles me with AMT
One is the front grille
If it was mounted on a dome tweeter or any other kind of driver, noone would buy it
And there would be good arguments why not
The other is less obvious
Its the folding of the diaphragm
Im sure theres lots of things going on in such a folded design
Phase issues maybe, or other nasty things
But it seems the avantages of the AMT are enough to keep in front
Technically, planars with edged coils on the diaphragm should be superiour
But fore whatever reason its not
But maybe it will be, in time
To ESL or to Ribbon? PhaseLockLoopy Planars & Exotics 83 5th August 2011 01:01 AM
Diy ribbon ABJensen Planars & Exotics 35 9th July 2009 08:52 AM
Fountek ribbon tweeter 3cm2 ribbon black square alumunum faceplate lduarte1973 Multi-Way 3 16th June 2009 09:50 AM
Ribbon Help berr4880 Planars & Exotics 14 8th January 2008 03:23 PM
SS 95/vs/97/vs/ribbon 5th element Multi-Way 12 27th January 2004 06:22 AM
Page generated in 0.11818 seconds (78.90% PHP - 21.10% MySQL) with 10 queries
