Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 25th May 2010, 02:44 AM   #61
mavric is offline mavric  United States
mavric's Avatar
Default high voltage low ampere
My conculsion would be that the more surface area of the wire or winding, would be stable at high voltage. I know currunt flows around the wire and not thru it, so to me, that cheaper coil may be more efficient. But the load would be compramised, i believe there would be more resistance using the cheaper coil. just some thoughts.
The only true wisdom is in knowing you know nothing.
A wise man does not need advice and a fool won't take it.
Old 28th November 2011, 08:12 AM   #62
Calvin... you have got me ordering two of these
http://www.antekinc.com/details.php?p=33
You have mentioned 6v and I read someone else say minimum 25v... he was probably talking full range?? Regardless I will get either the 25v or 6v 50va. Always remember regarding math and electronics I never know what the help I am talking about. Merely typing and ordering...
Old 28th November 2011, 08:23 AM   #63
SM7UYJ is offline SM7UYJ  Sweden
SM7UYJ's Avatar
With 25V sec. you get 230/25 = 9.2, using two toroids you get a teoretical transformation ratio 1:18 - unfortunatly way to low!
With a 6V trafo you would get 230/6 = 38.3, two toroids => 1:76
So using the 25V version trafo, you will need 8 toroids to get abt. the same transformation ratio as using two 6V!
/Roger
The probability of someone watching you is proportional to the stupidity of your action.
- A. Kindsvater
Old 28th November 2011, 08:24 AM   #64
CharlieM's Avatar
Antek - AN-0525
For hybrid ESL's, I recommend a pair of these trannys driving each panel:
http://www.antekinc.com/details.php?p=27
Old 28th November 2011, 09:15 AM   #65
Calvin is offline Calvin  Germany
Calvin's Avatar
the theoretical U is N1/N2 or V1/V2, which gives 1:76 for a 6V/230V pair.
Connected in parallel on the 6V-side and in series on the 230V-side.
In praxis You need to include the efficiency of the tranny, which is typically around 90% in the required wattage-class.
So the effective U would be 1/(76x0.9) ~ 1:68.
jauu
Calvin
Old 28th November 2011, 09:22 AM   #66
Never order anything until I talk to you all. Luckily I waited as I was about to order the 25v version...
Old 28th November 2011, 09:24 AM   #67
Smile I am going to have to dive into some electrical theory
/Roger
Later. Okay, thanks!
Old 28th November 2011, 09:33 AM   #68
Smile took your advice and ordered 2 per speaker
Antek - AN-0506
just tell me what to do.
Going to order a variable low power high voltage supply prebuilt. Know enough to do that I believe on my own.
I think I need a high voltage multiplier... found those on ebay. Some resistors high voltage.... well do me a favor... I will stay at this thread and update it with what I bought or thinking about buying.
Old 28th November 2011, 09:41 AM   #69
What is this update boxes thing on the antek order site? That is strange.
Old 28th November 2011, 09:59 AM   #70
Well I ordered 8 of those AN-0506 transformers. i have spare metal and family. As I am still learning I am forced to ask this question. If I use 3 of those per speaker would it be enough to drive a full range... say to 100-150 mhz if I should decide to do a design like that later?
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 08:19 PM
WTB: 43-0-43 or 46-0-46 Toroids K-amps Swap Meet 3 17th November 2006 08:03 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
High power toroids source Lupulroz Swap Meet 10 30th July 2003 02:38 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 12:54 PM
Copyright ©1999-2013 diyAudio
