Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 3rd October 2009, 10:38 AM   #21
CharlieM's Avatar
Followup: A week or so ago I emailed Antek asking if their 50VA 2x115V / 2x6V toroids used grain oriented cores and what the insulation values are between prim/prim & sec/sec windings but I've gotten no response so far. I suppose at $13 a piece they're cheap enough I wouldn't get burned too badly if I bought some to play with-- which I may do that at some point but for now I'm gonna keep looking for 230v/6v toroids with single windings; although I expect it will be hard to find a source that will ship to the US.
It's not like I'm desperate to find some-- just curious if changing from my current 100:1 EI core trannies to a tandem 68:1 toroid setup would improve my speakers' high frequency response. I like a lot of treble, since I'm a bit treble-deaf, and I'm having to add quite a bit of EQ boost above 5khz to get it where I like it.
Again-- If anyone out there finds some suitable cheap toroids available here in the US, please let me know. Thanks all!
Old 4th October 2009, 12:07 AM   #22
Few is offline Few  United States
I think you should try these instructions for winding your own and then let me know how it all turns out so I can learn from your experience
http://quadesl.com/pdf/trans_inst.pdf
Few
Old 4th October 2009, 03:03 AM   #23
CharlieM's Avatar
Geeze, I hope you're kidding.... thanks for the tip but your suggestion presumes that I would know what wire sizes to use and number of turns needed--- sadly I'm completely ignorant about all that stuff. Actually, I had thought winding my own but all the info I could find on it wasn't geared to ESL applications so I really wasn't able to learn anything. Old dogs don't learn new tricks easy anyway.
Old 4th October 2009, 05:09 PM   #24
The smiley face was meant to assure you I was kidding, but only because it was clear from the beginning of your thread that making a transformer from scratch wasn't what you were aiming for. I'm sure we could each figure out how to wind a transformer as Sheldon describes, but I don't currently have the expertise to make intelligent design choices any more than you do. Maybe someone else can chime in with a way to distill the design choices down to something newbies can work with. Until that happens, I'm with you in your quest for a source of relatively inexpensive toroids that'll get the job done.
Few
Old 5th October 2009, 10:03 AM   #25
CharlieM's Avatar
yeah, Few, good idea...
I'm sure we're not the only ones that would welcome someone posting a tutorial on winding trannies for ESL's!
Old 5th October 2009, 10:21 AM   #26
Calvin is offline Calvin  Germany
Calvin's Avatar
have a look at Amplimo datasheets and the Patent of Mr. v.d.Veen
publ.-no.: 9300433, Int.-Claims: H01F 19/02, H01F 27/28, Date: 03,10th,1993
"Step Up Transformator" (in Dutch, maybe therīs an english version too)
jauu
Calvin
Old 31st October 2009, 12:51 PM   #27
Calvin,
Can I use a standard 50hz step-up transformer for a full-range ESL?
I am an American living here in Beijing right near the "Silicon Valley of China", which is an electronics market with a goldmine of every kind of component for cheap.
I was just there today looking at tons of giant El and toroid transformers, but when I told them I wanted to use it to step up a 20-20K hz audio signal they told me it wouldn't work because they were designed for 50hz. Is this right?
What specs should I look for in these transformers here to find some that will work for ESL's? These places can even custom-make them for me, but they seem very confused by the 20-20K hz issue and seem to only make standard 50hz transformers.
Thanks!
Old 31st October 2009, 01:24 PM   #28
Calvin's Avatar
Q: Can I use a standard 50hz step-up transformer for a full-range ESL?
A: probabely not, but not because it is designed for 50Hz usage but because of a too low primary inductance and maybe wrong core material.
You need lots of primary inductance to reach down to 20Hz, more than normal power trannies have. For hybrid panels working >200Hz prim inductance is usually sufficient. The core should be wound from thin grain oriented material, not ferrite or similar. Then bandwidths >20kHz are possible.
jauu
Calvin
Old 31st October 2009, 10:34 PM   #29
Calvin, thanks for your answer!
1) "too low primary inductance"--what value of primary inductance would I be looking for to reach down to 20 hz? What determines the primary inductance, and is it helped by having larger toroids, i.e. 100VA or more?
2) A core of "thin grain oriented material, not ferrite or similar"--what specific material should I ask for ideally?
The great thing about these markets here in Beijing is that I can have them custom-make almost anything I want. What are the idea specs I should ask for for ideal trannies for full-range ESL's?
Old 1st November 2009, 10:00 AM   #30
Calvin's Avatar
Hi
I repeat:
jauu
Calvin
Source follower and common source output stages slogan2112 Pass Labs 2 9th October 2008 09:19 PM
WTB: 43-0-43 or 46-0-46 Toroids K-amps Swap Meet 3 17th November 2006 09:03 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 01:55 PM
High power toroids source Lupulroz Swap Meet 10 30th July 2003 03:38 PM
Source follower electret mike -> use with current source? capslock Solid State 1 28th February 2003 01:54 PM
Page generated in 0.09868 seconds (87.62% PHP - 12.38% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
