| Planars & Exotics ESL's, planars, and alternative technologies |
Banned
i originally posted this a few days ago on another forum:
------------- By George Chkhartishvili September 6, 2009 The purpose of this public post is to document my invention thereby establishing prior art for it. Ultra-High performance loudspeakers must energize a diaphragm of large surface area in a manner that will: 1 - Minimize diaphragm flex throughout operating frequency range 2 - Maintain linear driving force throughout the range of excursion The only technology to date that I believe has fully met these criteria is the electrostatic loudspeaker panel ( ESL ). ESL achieves this by having a driving force ( electrostatic field in that case ) that is UNIFORM IN 3 DIMENSIONS throughout the entire region of space where any part of the ESL diaphragm can find itself at any time. ESL would have been perfect if not for two inherent problems: 1 - ESL loudspeakers provide a difficult load for an amplifier 2 - ESL loudspeakers must be very large to produce high output Ribbon speaker is a competing technology which doesn't have the above 2 shortcomings of ESLs but also didn't have the advantage of driving force linear in 3 dimensions - until now. The technology presented here essentially combines the benefits of the two technologies ( ESL and Ribbon ) without the shortcomings of either. Physical design of linear ribbon transducer has a geometry similar to that of an ESL panel. This is the source of its inherent linearity and uniformity. In the design presented here a ribbon panel ( can be of any height and any width, just as in an ESL speaker ) is situated between two magnets ( where the Stators would be in an ESL ). each magnet is shaped like a flat sheet ( of Neodymium or any permanent magnetic material ) with the direction of magnetization running not through, but ALONG the surface of the sheet. both magnetic sheets are magnetized in the same direction. The magnetic field lines going through these magnets find their way back ( for the flux to complete the loop ) around the magnets but also between them, thus forming a magnetic gap. The flat magnets are perforated to allow sound to pass through ( just as the stators are perforated in an ESL ). In practice the perforated magnetic sheets can be replaced by 2-dimensional arrays of small magnets of any shape ! The array need only approximate the shape of a sheet. No steel is needed for the motor structure, just the permanent magnets. The current flows in the ribbon panel ( thin, wide sheet of aluminum foil or any other suitable construction ) in a direction perpendicular to that of magnetic field lines in the gap. The resulting force is perpendicular to the plane of the ribbon and that of the flat perforated magnetic sheets. Here is a finite element analysis simulation of a horizontal cross section of such a ribbon: ![]() The two sheets of neodymium look like thin bar magnets in this image because it is a cross section. To understand this diagram imagine that you took a 2 meter tall, 4" wide ribbon, cut it in half and are looking at the cut from the ceiling. The thin horizontal red line denotes a plane where the ribbon surface would be situated. Here is a magnetic field magnitude plot through that red line: ![]() As you can see it is possible to create a wide region where field strength is uniform to a very large degree. This ensures that the entire surface of the ribbon is driven uniformly ( in this example using 4" wide neodymium sheets a ribbon of about 2.5" width would be uniformly driven ) ensuring minimum flex possible and therefore minimum amount of related distortions. Observe now field uniformity along a different axis: The thin red vertical line here represents the range of motion of the ribbon. Here is the corresponding plot of the normal ( perpendicular, or effective ) field intensity along that line:![]() Uniformity in this plot is by far more important than in the previous one because any nonlinearity here will DIRECTLY translate into distortion. The graph doesn't seem particularly flat until you look at the scale to the left. 100*(0.0611 - 0.0609)/0.0611 = 0.3% The maximum deviation of normal ( perpendicular ) field intensity throughout the ONE INCH of peak mechanical excursion range is only 0.3% ! ! ! This linearity of 99.7% would in itself be impressive but in normal operation the excursion of the ribbon will be of course much smaller. The flat and symmetrical plateau in the middle of this curve means B field will be approximately 99.99% linear for normal range of excursions ! ! ! This number means the technology is theoretically capable of distortions as low or lower than the best audio amplifiers. But most importantly the inherent symmetry of the curve ensures that as excursion decreases nonlinearity tends towards zero. To summarize PLUR driver is superior to: ESL - because it is more efficient, compact and an easier load on the amplifier. Push Pull Isodynamic - because the entire diaphragm can be a conductor that is uniformly energized Traditional Ribbon: - because the B or BL curve ( force vs excursion ) is both linear and symmetrical in PLUR while it is neither linear nor symmetrical in a traditional ribbon. This potentially reduces distortion by orders of magnitude. This linearity is a function of a geometry that uses two parallel planes to set up a field between them. It is the same geometry that produces the same linearity in an ESL speaker but PLUR applies it to static magnetic ( as opposed to electrostatic ) field. George Chkhartishvili September 6, 2009 Last edited by Borat; 11th September 2009 at 03:57 PM. |
#2 |
Hi Borat,
Your invention is very interesting. Have you actually built one? I'm looking forward to seeing more of your progress. Thanks for sharing. Wachara C.
#3 |
Banned
no haven't built it. i just came up with the idea recently.
i am traveling right now ... when i can have some peace of mind i will have to assess what building a prototype might involve. i never built any ribbons before so i can't say right now whether i will build one or not. why don't you build one ?
#4 |
#5 |
May I ask a question? From the field line diagrams, I can only assume that a current carrying element -the ribbon - passes into the plane of the diagrams of the B field analysis? Another way to think of the design is that the ribbon sits within the field that would exist inside a hollow magnet. Am I correct?
You certainly get a superb uniformity. The overall field strength (as shown in the simulated configutation) is only a small fraction of what could be achieved with the same NdFeB magnets in the more common gap designs. However, I don't know what the field strength is like in systems such as the Magnepan speakers (no Neo magnets there, and wide spacings) so perhaps this configuration could be rather promising if sufficient BL product can be devised. Ed |
#6 |
I'd love to see how this turns out.
In my work with magnetic materials (generally softer than NIB) I've noticed that the alignment you use tends to significantly shift the north poles internally (to lower the energy of the system). I'm not sure if this would always come out in simulation. Not insurmountable, but something to look out for if your uniformity is not what you exect.
-roomatthebottom |
#7 | ||
Banned
![]() in a 3D view it would be like this ( diagram by NeoDan from another forum ) ![]() so in this diagram you see two arrays of neodymium bar magnets. and the ribbon element would go right between the two arrays. Quote:
#8 |
Banned
compared to a regular ribbon which, admittedly, would have a much stronger field, my driver would have much larger surface area because it is able to create a field across a wide ribbon.
in a conventional ribbon as you try to make it wider the field strength drops dramatically. so much so that perhaps 99% of all ribbons stay at or below 1" wide. but in PLUR there is no strong relationship between ribbon width and field strength. field does get a tiny bit weaker in the middle of the gap and stronger at the edges ( thats why in my simulation my magnet is about 5% thicker in the middle than on the sides ) but this effect is very minor. in other words unlike in a conventional ribbon you could double the ribbon width and lose very little field, maybe 5%. you can make it as wide as you want basically. you can make it a foot wide. and doubling the width automatically gives you extra 6db of output. so compared to a conventional ribbon PLUR can use its width to compensate for weaker field to bring output back up. compared to magnepan it has all of the diaphragm conducting. if magnepan has 1/3 of its moving mass in conductor the it will need 3 times the field strength for same output. |
#9 |
Could be a really cost-effective way of building ribbons. It really could be that IŽll become a ribbon builder now.
http://cgi.ebay.de/200-Neodym-Magnet...4.c0.m14.l1262 |
#10 |
Since these line of force do not cut thru the ribbon anywhere,
how is it a current applied to the ribbon supposed to move it? |
