| Planars & Exotics ESL's, planars, and alternative technologies |
#11 | |
It was only ONE of several points Also dont forget that having just a couple more signal strings makes it possible to make them a bit wider, and maintain the same impedance Which will result in improved power handling I have made several long ribbons, a long time ago And I do remember the flapping back and forth Completely out of control at anything higher than "normal" low SPL Sure, you can deal with that by using steep aktive filters, or higher xo point I would like it to go down to 300hz Last edited by tinitus; 23rd September 2009 at 04:46 AM. |
#12 | |
By reducing the mass of the ribbon, you are simply approaching the mass of the air. The differences in mass quickly become negligible and an increase in sensitivity may not necessarily be observed.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." Last edited by thadman; 23rd September 2009 at 05:25 AM. |
#13 | |
#14 | |
Hello Line source , Interesting , as i have never seen a big ribbon having 90 Db/2.83 V/M sensitivity , could you explain more . |
#15 |
Sure, but not possible with corrugated ribbon
Another significant problem with tention, be it ribbon or planar, is the resulting "drumskin-effect" And the tendency to "rattle" Which makes the corrugation crutial Last edited by tinitus; 23rd September 2009 at 01:40 PM. |
#16 | |
Banned
#17 |
Instead of mass, you may consider compliance. Would you not admit that a weaker spring is easier to deflect (less required force) than a stronger spring?
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them." |
#18 |
Banned
but compliance only becomes a factor at lowest frequencies. it would effect a cutoff frequency more than efficiency.
#19 |
| Metal strength for enclosure | rtarbell | Parts | 5 | 6th September 2008 07:39 PM |
| is thier any way to strength a radio Aetna?? | prorms | Solid State | 1 | 20th August 2008 12:18 AM |
| Electrical field strength | Bazukaz | Planars & Exotics | 5 | 13th June 2006 03:31 PM |
| maximum inputsignal strength(V) on the lm3886? | demogorgon | Chip Amps | 2 | 9th December 2004 08:11 PM |
| DIY Field strength meter ! | darkm4n | Parts | 7 | 3rd February 2004 08:04 PM |
| Page generated in 0.11151 seconds (81.94% PHP - 18.06% MySQL) with 11 queries |
