Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 1st September 2009, 12:31 AM   #21
Instead of Neodymiums with health warnings like "will break fingers",
and assembly procedures described "might swing around explosively"
Have you guys considered a simple field coil???
Old 1st September 2009, 12:46 AM   #22
paulfx is offline paulfx  United States
Well I wish I had joined this excellent forum before almost breaking my fingers putting this thing together!?
How much current would be needed to get the same kind of output? More generally could a short electromagnet be trial-built that would, say be almost impossible to get off the front of a refrigerator when energized?
Old 1st September 2009, 07:13 PM   #23
Have you ever tried to force open a maglocked door???
I think thats less than an amp...
Old 1st September 2009, 10:42 PM   #24
Default Maglock Strong
As a matter of fact, I work at an airport, we have them all over!
Do maglocks use DC? If so, how many volts? (I'm thinking power supply)
Old 2nd September 2009, 11:38 PM   #25
I just asked our technician here at the airport, and he told me maglocks typically use 24VDC. Probably too noisy to use the power supply, but that could be constructed. One or two of those...
Old 3rd September 2009, 01:19 AM   #26
cuibono is offline cuibono  United States
cuibono's Avatar
Its a cool idea - I wonder if there would be an even flux density through the diaphragm area, and if not, what effect that would have. I guess the next question is what current, resistance and wire gauge. It should be pretty easy to setup...
Old 3rd September 2009, 01:20 AM   #27
I think you might want a moderately high impedance current source?
Remember that any field coil might also act like a secondary winding.
I'm not sure how well leakage inductance moderates that effect???
Voltage protect (transorbs or crowbar) to handle any sudden collapse
or short across the magnetic gap... We still speak of crushing forces!
Just forces with an on/off switch.
I'm no expert on field coils, totally blind leading the blind here.
Maybe missing something critical? Definitely seek a second opinion
from someone who's actually done it before building anything field
coil supply-wise for audio. I am not that person.
Old 3rd September 2009, 09:05 PM   #28
Default Flux Consistency
Cuibono -
Uniformity of flux over time might be a deal-breaker if a huge delta in current spikes through the coil. Maybe we could get an EE to opine on this?
As for consistency over the plane of the diaphragm, that's no problem. These AMT's are very tolerant of imprecision. The Neo magnet I used is a bit stronger on one area of the flat pole surface, and this does not seem to have affected the sound. Even the ESS models had a good deal of manufacturing variance.
Old 3rd September 2009, 09:45 PM   #29
Maybe you also want one big shorted turn on the pole? That would effect only AC fluxes,
and not the DC flux that is present continuously... Sorta like JBL has a shorting ring???
I'm not sure shorting a turn, thats any diff than a low impedance style voltage supply???
But I'm pretty sure we don't want said power supply to look like 8 ohms, seen through
a transformer. Else your amp is gonna work into that load maybe instead of the parts
that should be moving.
Somebody has done this voice coil thing before. Its gotta be documented somewhere...
Why am I not finding it? Other than my Hammond organ...
Old 3rd September 2009, 11:26 PM   #30
cuibono's Avatar
kenpeter, I had a different picture in my head (if I understand you) - I had thought we could wrap the edge of the diaphragm in wire, then run dc through it to create a magnetic field through the diaphragm - basically an 'active' tweeter. Of course, the diaphragm's wires would be connected to an amp as usual.
Stuart and Neil Build a KSA 50 (tweaked for 100 watts) neil_kaye Solid State 12 11th November 2008 02:51 AM
Neil Young Recording Fans Trout Music 24 29th October 2006 07:31 PM
Neil Young's new CD infinia Music 55 15th May 2006 05:46 PM
looking for Betty Davis Artmaster Music 0 8th July 2004 11:33 AM
Page generated in 0.14635 seconds (61.30% PHP - 38.70% MySQL) with 11 queries
