| Planars & Exotics ESL's, planars, and alternative technologies |
#21 |
"Trying is the first step towards failure" -Homer Simpson |
#22 |
#23 |
I can understand the see trough aspect, but it also means that you have to choose between good sound and good looks....but I agree that see trough is very important, look here at my speaker!
Picasa Web Albums - Jonas - Drop Box It has a very low resonance peak in the audible spectrum. I suspect that this fact is due to that the weight of the stators dampens the 15-20 hz (with dismounted stators) resonance. Another way is to place a 5 to 10 ohm resistor paralleled with a 50 uF audio capacitor in series with drive transformer input, to form a high pass filter. It also have the benefit of putting less low frequency energi strain into the transformer. Do some experiments with different values. |
#24 |
JarreYuri, what's so funny?
#25 |
#26 |
It's really a very beautiful project and I hope I could do the same work here.
May I ask one question?What high voltage bias do you use in the design? Thank you very much. |
#27 |
Finally, the weather was bad enough for to do some measurements (not to go to fishing trouts
But first, the high voltage, I don't know... A little bit lover than the sparks There's quite a lot noise in my impedance measurements, but I guess the message is coming trough anyhow. 1st one is plain panel, 2nd with 1 ohm series and 2.8 Ohm parallel "RS". Now I have 1.8 Ohm parallel resistor and there's still bit of a bump in the impedance curve (I'm pretty sure that if I go to 0 Ohms it will level out Now I have to try out that software and see if I can manage to create a circuit that is behaving like the measured one. Or are the measurements way of what they should be?!?
"Trying is the first step towards failure" -Homer Simpson Last edited by vmk; 29th October 2009 at 01:09 AM. Reason: guess |
#28 |
LSP-CAD is working fine
Something funny is going on with my measurements, much lower impedance bump this time. Have to make a prober circuit to measure the thing (now there's just a awful pile of leads everywhere and I'm using headphone amp of my stereos on top of that). A couple of new charts below anyway, 1st panel only 2nd with RS+200uF series capacitor. Been playing with the LSP-CAD and trying to get the notch filter values, it seems that I will end up with a huge inductor for the RLC-circuit. 50mH to get it down to 50Hz. Too big, but I still have hope, I'm probably doing something wrong here.
"Trying is the first step towards failure" -Homer Simpson Last edited by vmk; 29th October 2009 at 03:28 AM. |
#29 |
Very Weird impedance graphs , is there any filtering being used ? I would try another software ..
#30 |
Too complex for me, back to 8.2 Ohm parallel resistor, because lower value resistor also kills bass starting from 500Hz. Argh. Tomorrow I will go fishing!
| Page generated in 0.10720 seconds (79.68% PHP - 20.32% MySQL) with 10 queries |
