Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 26th July 2009, 02:36 PM   #21
thadman is offline thadman  United States
Originally posted by a.wayne
This focus on diaphragm weight is not that big a deal as many would think. we are already dealing with a very light diaphragm , there are other bigger issues..
.. With the case of the Heil -T , the diaphragm is focused in such a heavy field i do believe mass is not it's Achilles heel , but more a problem of the reflective energy within such a fold ...
I do not believe mass is an issue at all for ribbon loudspeakers at any appreciable thickness. The figure we are interested in is the total mass of the system, which includes the mass of the air behind the driver...which pretty much means the mass of the ribbon is insignificant.
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 26th July 2009, 02:41 PM   #22
Telstar is offline Telstar  Italy
Originally posted by Mx
I like the idea! I'am also active crossover fan (analog and digital), so you have my attention. If you do that, please post something.
Probably I'll never attempt it because i cannot find an EFFICIENT heil or true ribbon for the task. Need 95+dB.
I'm now considering normal (above woofer) mounting of either of great heil/beyma/kithara, or going more extravagant with a Rubanoid.
The response of the inner ear extends to at least 200khz - Dr W. Tempest
Old 26th July 2009, 05:20 PM   #23
Mx is offline Mx  Yugoslavia
@ Thadman Mass is issue when you're trying to design ribbon with greater sensitivity. And if having uniform field means less magnetic induction, then lighter membrane becomes a problem especially for quasi ribbons.
@Telstar You can also try Rall ribbons.
Best regards
Old 27th July 2009, 04:14 PM   #24
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Length to width ratio's play a significant role there more so than ribbon weight !
Sources of distortion in ribbon loudspeakers thadman Multi-Way 1 1st July 2009 06:38 PM
Ribbon distortion jirka Multi-Way 4 2nd October 2006 08:22 AM
Ribbon Tweeter Distortion angsuman Multi-Way 50 7th May 2006 03:08 PM
Ribbon Loudspeakers, Theory and Construction by J.V.Verhagen, Ph.D wuffer Planars & Exotics 1 21st January 2006 10:51 PM
Correct my thinking on distortion mechanisms mashaffer Solid State 10 28th July 2004 12:58 AM
Page generated in 0.07466 seconds (72.33% PHP - 27.67% MySQL) with 10 queries
