Asymmetric construction induced distortion in electrostatic speakers - Page 5 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 14th June 2012, 04:22 PM   #41
bolserst's Avatar
Applying bias to the diaphragm does result in a charge induced negative tension increment.
I posted some plots of this behavior several years ago when I didn't understand what was going on.
arend-jan was kind enough to point me to the Peter Baxandall chapter on ESLs which discusses it in detail.
Diaphragm Resonance change with HV bias
Taking a look at the negative stiffness term of the force equation....
F= Eps0*A*2*Vbias²*x/d³
You can see that it increases as square of Vbias, but decreases as cube of D/S spacing. So, for the same panel area and diaphragm tension, if you double the D/S spacing and double the Vbias value to obtain the same efficiency, the negative stiffness term will have less affect on Fs.
Plots comparing negative stiffness trends for different D/S spacing posted here (Attachment 3):
Current vs voltage drive ESL?
In your case you have small areas due to segmentating the diaphragm into smaller sections, and your D/S is fairly large(3-3.5mm I think you had said). So, you may see only very small changes in Fs with bias change until you start getting above 8kV or so.
Asymmetric drive to asymmetric loudspeaker tolits Multi-Way 5 11th January 2008 05:14 PM
Class D for electrostatic speakers koldby Class D 23 4th December 2007 04:10 PM
Electrostatic Speakers & Amp ralph-bway Multi-Way 28 6th July 2003 06:43 PM
electrostatic speakers junglejuice Planars & Exotics 3 22nd October 2001 09:32 PM
Copyright ©1999-2017 diyAudio
