Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 8th May 2009, 10:38 AM   #1
Kabeern is offline Kabeern  United Kingdom
Default How to repair fine traces?
I need some help kinda quick.
Basically how to apply liquid ink (or something better?) in a very fine and thin manner?
I have a ortho/magnaplanar/isodynamic, whatever you wanna call it driver (specifically one from a Yamaha headphone).
There is a break in the diaphragms coil.
Here is a photo of the type of diaphragm im reffering to:
Diaphragm photo
The whole diaphragm diameter is about 50mm, to give you a rough idea of size.
Current plan to repair the broken trace is to use liquid conductive ink from a conductive pen. But the problem remains on how to apply it very finely so it doesnt affect the diaphragm too much, and to minimise it touching the other traces (although touching a few traces isnt going to kill it).
Basically all we can think of so far is using a finger to dab a little ink on....
Help is greatly appreciated, thanks!!!
Old 8th May 2009, 11:43 AM   #2
The picture that you link, although interesting it may be, isn't working. Try to attach it to your post intead.
Old 8th May 2009, 11:49 AM   #3
SY's Avatar
Conductive ink may need to be thinned slightly with MEK- it tends to blob up. I'd use the tip of a pin to pick some up and touch it to the right spot. Magnifying glasses and a means to brace your wrist (a Mahl stick could work) would be very helpful. Be relaxed, don't drink coffee beforehand.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 8th May 2009, 02:01 PM   #4
dBel84 is offline dBel84  United States
Sy , I have wondered about solvents to thin out the conductive ink. Do you think the MEK is safe to use on a 12micron polyester membrane? TIA ..dB
Old 8th May 2009, 02:07 PM   #5
Methyl Ethyl Ketone is not good for your PET film. Even short (1 minute) exposure will result in decreased yield stress and stress at break. That being said, for this application I doubt it would have serious consequences.
Old 8th May 2009, 02:24 PM   #6
this was my concern, even at short / small exposures..dB
Old 8th May 2009, 02:26 PM   #7
Sorry about that. I uploaded it to my flickr account now ~(click to enlarge):
Thanks! Actually, dBel84, who posted below you will be carrying out the repair. So let's see if he thinks its possible to do...
Old 8th May 2009, 03:51 PM   #8
bear's Avatar
They make a copper liquid for repairing the heater/defroster on the back of car windows. That withstands heat well and conducts.
Try that. Auto parts store. Look for the copper containing one.
_-_-bear
I'd also consider painting the surrounding area with a thin lacquer or other thin insulating coating before applying the conductive paint - a mask effect. You might be able to use something that has an easy solvent removal like a wax... when I say paint, I don't mean very much,just enough to insure that you don't short a turn.
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 8th May 2009, 04:45 PM   #9
These headphones work on a planar principle and as such the sound is intricately connected to the speed of the diaphragm. One of my biggest cautions with trying to repair this driver is not to change the density/weight unevenly on the single surface and more importantly, relative to the second driver - any imbalance is easily perceived in headphones and would negate the initial effort.
I speak from a little experience here as I have unfortunately had to repair a similar driver for another friend and the repaired driver works well but the channel imbalance is frustrating and measures to correct this imbalance have resulted in an inferior sound ( it is still superb but not as good as it was and this knowledge gnaws away while using them)
thanks for all the input, the collective process may yet yield a simple solution..dB
Old 8th May 2009, 06:26 PM   #10
SY's Avatar
There's only a brief exposure in a small area. It's unlikely to have a bad consequence. The nice think about thinning with MEK is that the added mass will small and the drying time will be very quick. Ethyl acetate would also probably work as a thinner but is a "slower" solvent.
Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? danielwritesbac Solid State 4 30th December 2007 03:29 PM
Traces in Ultiboard loovet Everything Else 1 29th November 2007 11:35 PM
Question about curved PCB traces... Cameron Digital Source 18 19th August 2004 06:40 AM
Do these scope traces mean something is oscillating? Saurav Tubes / Valves 23 5th August 2003 04:12 PM
Amp PCB traces style rborer Solid State 7 24th January 2002 08:49 PM
Page generated in 0.11983 seconds (82.08% PHP - 17.92% MySQL) with 10 queries
