| Planars & Exotics ESL's, planars, and alternative technologies |
Does anyone have a simple 101 ribbon DIY system that they can share of how to build from scratch for a novice?
List of parts needed, drawing, everything needed to make such a system? |
#2 |
Not mine but everything else you asked for.
Here you go: http://www.dahlbergaudiodesign.se/engelska/del1.htm |
#3 |
Nice setup - but I might start with something a bit shorter to get a hang of the methods!
I think there's quite a bit out there on DIY ribbon tweeters if you search. With a few magnets and some foil (and a step down transformer), it's pretty easy to experiment. Beware low impedances presented to an amplifier... Cheers, Ed |
#4 |
http://www.michaelgaedtke.de/Home/index.html
Look at "lautsprecher", and use a "translate" program But with smaller ribbon you need a trafo, which you may not with bigger ones But I have made very big ones and they are a bit tricky and "lively" when crossed low The more advanced DIYers have turned towards "planars" One important thing to consider is diaphragm weight, and even glue ads up I think one problem with ribbons is that they dont have much lowend power, unless maybe if VERY BIG, so I would still use some kind of ordinary mid/woofers My present projects are a 15mm x 200mm and 8mm x 100mm, more or less Still thinking about how to do the iron work...but I may have the wrong magnets fore some options Man, there are some real heavy neos, and perfect fore small ribbon with very high sensitivity...but man, those are very strong and literally dangerous to handle Be aware that magnetising orientation is very important, and determines to some degree how the iron is placed |
#5 |
[QUOTE]Originally posted by tinitus ...but man, those are very strong and literally dangerous to handle [QUOTE]
VERY dangerous. Check this out if you don't believe me. http://www.magnetnerd.com/Neodymium%...20Accident.htm |
#6 |
ouch!
#7 |
I suppose that big a neo is so expencive you wont buy it anyway
#8 |
I once had this idea with a VERY big ordinary magnet I once saw, but so big a magnet even if ordinary and not neo may still be tricky to handle
Even so, its an odd design and difficult to mount properly |
| diy ribbon tweeter project | paulfk | Full Range | 1 | 24th October 2008 02:51 PM |
| simple ribbon pleater | george a | Planars & Exotics | 5 | 5th February 2008 08:14 PM |
| Help with ribbon project | bizza | Planars & Exotics | 7 | 19th October 2007 05:07 PM |
| How about theese N52 magnets for a ribbon tweeter project? | swak | Planars & Exotics | 4 | 8th December 2006 03:54 AM |
| JP2.0 Project Part IV : How to blow up a ribbon and scare the life out of your cat | DIY_newbie | Multi-Way | 22 | 13th April 2005 06:20 PM |
| Page generated in 0.08691 seconds (78.45% PHP - 21.55% MySQL) with 11 queries |
