| Planars & Exotics ESL's, planars, and alternative technologies |
I am thinking of making a pair of BG Neo8 mtm's with the Neo3PDR's in the center. I was going to cross them over to 4 Dayton RS100 full range speakers at about 1500hz. Also will have Dayton RS265's in bottom of enclosures with 240 watt amps. I was thinking this may work out? Subs at 180hz then full ranges to about 1500hz and finally tweeters at 8500hz? all 2nd order (APC) or may be even 3rd order(APC) for the full ranges? Im wondering if this will work with the RS100's stacked vertically in a closed box right next to the MTM Neo drivers which would be mounted on there own open baffle? Or will that type of arrangement interfere with the open back diapole effect of the Neo8's? I think I have seen similar designs from speaker manufactor's. Also would it be better to just do a 2-way cross-over with a single cap on Neo3's treated like super tweeter's? Any help will be appriciated because I am about ready to order the Neo8 or Neo8PDR's.
#2 |
I almost forgot one of my main questions, does it make any difference which Neo8 I use, PDR or regular? Thanks
#3 |
In my experience I suggest to use The Neo8PDR without neo3
Obyouvsly one Neo8pdr, not two. And personally I have found it better in monopole than dipole operation. Make a little box 100%stuffed 1 liter or more. Just my 2 cent. Cheers, Paolo |
#4 |
Makes sense...too many drivers may cause difficulties, to say the least...the ideal is one driver fore each passband, if possible
Hey, my old mentor would like your statement about monopole being better You seem to have had some good thoughts about this, and maybe just needs a bit refining |
#5 |
That 10" sub driver, I dont know, its too small
That little RS100 is really cute, but I wouldnt use a mid with such peaks And I wont say that the use of 4 mids cant work, a way around it could be 2.5way + sub Only 2 drivers would probably sound better, but with less sensitivity and power Maybe the underhung 4" Titanium Tangband..as above Would probably work fine with a pair of RS270S The new longstroke underhung Tangband actually looks quite interesting...as above Would probably work fine with good subs Well, personally I wouldnt place my money on Neo8, it may be ok though, I dont know my my, that was grumpy, time to bed
#6 |
some other thoughts popping up
If monstersound is whats needed, probably the new bigger underhung Tangbands will be a good choice But maybe 3 x 4" titanium TB in a MTM, with one working as tweeter...ehhh, say what Yeah, I believe it would work And crossed as you like, "6db" possible too supertweeter on top, if needed Thinking, maybe a couple more of the same driver below, in 2.5way Lets see...that would be WWWWMTM +sub...all drivers the same, 7 drivers in total +subs...thats cool ![]() The above MTM top section could also be combined with their bigger underhung sister woofers...yeah, could bee the one, but unfortunately the simple 2.5way is down the drain Ok guys, thats crazy stuff...and I am not the one to make it work, so its quite easy Though I have other plans fore myself...but surely this thing has me on my toes, so maybe I will think about doing such a thing Especially now that these drivers are becoming more available in EU But VIFA have announced new interesting drivers, so we will see about that |
#7 |
Sorry Justin, I shouldnt have done that, but the bright side took over
#8 |
tinitus thanks for the advice. I really am not after high spl's in any way. My main goal is to design something that images incredibly and sounds very life like. I want that "spooky" solid image that fools you into thinking the real thing is right in front of you. Im kinda disappointed to hear that the Dayton Reference 10" woofers are so poor because I purchase two fo them and two 240 watt amps for this type of project. Im really not as concerned with extremely deep bass. I am more interested in transients, pitch and definition. I've read that closed box designs are better for or easier to make with these goals in mind? I was thinking of this design as sort of a really small line aray with supper tweeter in the middle to extend things past 20khz. I have a pair of satellites that I rigged together with 2 rs100's stacked vertically with a Neo3PDR side mounte in a triangle. I really like the sound of this combination as long as the volume is kept lowish. They do fall apart quickly once turned up. These very small drivers (rs100's) seem like they could use a little more help. 4 of them would be 120 watts and about 88-89 db instead of 85-86. and 2 Neo8s would be 8 ohms insted of 4 with lower sensitivity closer to rs100s. I have read a lot of posts about these drivers and it seems like most people liked them better diapole? I will probably try them both ways before I make final boxes. Thanks for the sugguestions, and please keep them comming, because the Neo8PDR's are not in yet.
#9 | |
you are right. I have "discovered" the Neo8pdr before the Martin Logan was emploing in his "horrible" AV line! I believe 99% of useres have understand "nothing" about what is the real value of the Neo8 ( that is very high) because they are not capable to employ it at his maximum! I'm sorry for my crude words but I have listened enough speakers wich sound "mediocre" ........ My statement is the Neo8pdr , when propery modified and emploied, do not need of any supertweeter. Never do that! I have speakers disponible for comparision here in Italy. Compare with what you want; I have checked with Avalon, Wilson,Thiel,B&W, Manger and Magico. I repeat, and excuse if I am annoing: they do not need neo3. I'm sorry, I dont want post photos because I am in doubt if make business here Cheers, Paolo |
#10 | |
Sorry, I was rude I believe your Dayton sub is a very fine driver...used correctly...only it doesnt seem to be the absolute best choice fore your suggested design...but doesnt matter when you read below As fore your last statement, you are right...just your design doesnt seem to be going in that direction...I believe other designs would be much better in doing what you really want |
| Neo8, Neo3PDR | Jonasz | Planars & Exotics | 2 | 18th August 2007 03:01 AM |
| open baffle neo3 neo8 line array design | Ang | Multi-Way | 2 | 10th January 2007 01:23 AM |
| B&G Neo8's | carstereogeek | Car Audio | 3 | 9th May 2006 07:19 PM |
| Page generated in 0.13356 seconds (83.74% PHP - 16.26% MySQL) with 11 queries |
