Ever been shocked by bias supply or stator? - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 4th May 2009, 08:08 PM   #21
Bernhard's Avatar
So which are the good models ? Are there any ?
If even the SR-404 model has a rather nasty midrange ?
Why does the much cheaper SR40 sound better than the lambda pro ?
Is it the driver or the implementation ?
I believe that one of the problems is the plastik cabinet on the back of the driver at a greater distance.
It gives interferences.
On the SR40 it is very close, so the interferences occur at a much higher frequency.
Old 4th May 2009, 09:45 PM   #22
spritzer's Avatar
The original SR-Lambda, Lambda Signature, Lambda Spirit (Pro Classic in Europe) and the Nova series are all excellent and the same goes for the very rare Airbow SR-SC1. The newest series is a bit of a step back as while they do many things well, they overlay a certain texture on everything which I can't stand. The same can be said about the new SR-007 Mk2 but I found a way to bypass most of the damage Stax did to the sublime SR-007 Mk1.
The electret models do sound quite nice and their faults are minor compared to many headphones out there. You may well prefer the slightly thicker sound of the electrets so something like a SR-5NB or even the older SR-3 would be a better match to your tastes. Just because they are low bias, doesn't make them bad by any means. Even the original Stax, SR-1, is stunning even by todays standards even if it turns 50 this year.
The plastic housing isn't doing the Lambda drivers any favors but I've never bothered to have something better made. I must admit that I'm more focused on getting better amps since that's the real limitation.
Old 4th May 2009, 10:26 PM   #23
Bernhard's Avatar
Yes, the SR40 is a bit thick and dark, just the opposite of the lambda, but I find it more pleasant.
Out of curiosity I tried a few things, among them, I attached breadboards ( the circuit boards with the little holes ) to the original grills ( I cut out every second bar already ) and it sounds much better, more mids and less peaky highs.
That is what the SR40 has got, a plate with small holes.
I think I will try different speaker grills with different hole sizes.
Do you know any tweaks to the SRM1 ?
Maybe bypassing the PSU lytics with film caps ?
Old 5th May 2009, 07:58 PM   #24
spritzer's Avatar
You certainly could bypass the main caps but I would also look into replacing them. The SRM-1's run pretty hot and most are at least 20 years old now. You could even modify the PSU and add a regulator though I'm not sure the transformer can handle the extra current needed.
Old 6th May 2009, 04:04 AM   #25
ilted is offline ilted  United States
I had a pair of homebrew 4'x1' panels a while back. The outside of the perforated steel was coated well but the insides were not. Anyway, late one night I was listening and saw a small daddy long leg crawl up the speakers and walk out on the panels. Within a few inches it simply poofed into smoke. Amazingly instantaneous, near silent, complete destruction of that poor thing. It was late, I had a few beers in me, and I was 6 feet away, but I'll never forget it.
Just fyi.
Old 6th May 2009, 05:39 AM   #26
chinsettawong's Avatar
Just fyi.
Just wondering, what song were you listening to?
Old 6th May 2009, 05:53 AM   #27
Andersonix's Avatar
I might regret admitting this, but today I was pressing against both sides of the stators on my ML SL3 to find a panel buzz while playing them loudly and felt mild shocks that got stronger with increasing force. It happened on both L and R, but only when playing loudly.
Old 6th May 2009, 01:05 PM   #28
Touching the stators of an ESL can be very dangerous, especially when you are playing music. Most of the ESL speakers are made of painted or coated perforated metal. If the paint doesn't do a good job of insulation, you are about to touch something with very high voltage. Please be very careful.
Old 11th May 2009, 04:40 PM   #29
Bernhard's Avatar
So again, a lambda pro signature won't have the peaky highs and the hole in the midrange ?
I start to read through the monster threads at head-fi and it seems there are contrary opinions about the lambda pro.
Anyway, I have found a trick to tame the highs of the lambda pro and I like the sound now.
I will report after some fine tuning.
Do the latest models still have too bright highs ???
Old 25th May 2009, 07:38 PM   #30
spritzer's Avatar
There is a certain inherent brightness to the Lambda design but it does vary from model to model. The Lambda Signature is often said to be bright but some of it is due to it being under amped. The 1um diaphragm isn't as stable as those that are thicker so you need more voltage to keep it in line... well that's the theory at least. I did have great results with my old Blue Hawaii amp (now sold and I'm waiting on a Headamp BHSE now) where the "etch" in the top end all but disappeared while being present on amps like the SRM-T1.
The new models have a rather nasty upper midrange peek which overshadows all the good aspects of the phones. I'm afraid that only rebuilding the drivers from scratch will fix it so I've ordered some 1.4um mylar to do just that. I still need to find a beat up donor set to experiment with as the chance of failure is quite high.
As for the monster threads, you have me to blame for that to some extent. 10%+ of the posts are mine...
Shocked!!! hdlcx2 Tubes / Valves 30 10th January 2011 05:41 PM
stator spacing/voltage bias tade Planars & Exotics 2 28th June 2005 05:57 PM
Copyright 1999-2017 diyAudio
