| Planars & Exotics ESL's, planars, and alternative technologies |
#11 |
My diaphram messures 120x980mm. and is made of alufolie witch paper in DK. it is used to ¨store food in.Thickness of alu is 0.007mm. + the paper.I cut it into coils of 8mm.wide. I use 11 meters to make a diaphram and the Resistance is 5 ohm.The tape is from 3M called microporre and for helth care.I cut it to coils of 3mm. wide.
#12 |
Hi there Båndsei,
Has 3m Microporre adhesive on both sides? I think we can coat it with conductive glue 0.01 Ohm per cm can we? |
#13 |
Microporre has only adhedsive on one side,and i dont think it is better to use conductive glue.
#14 |
Hi båndsei
That really is some very nice design work and high quality construction. What frequency coverage is typical from these devices? Also, how is the polar dispersion in comparison to a flat panel? Thank for sharing this project with us, Cheers Ed |
#15 |
My curved planarspeaker has not been tested,but i think it goes from 150 hz to 18000 hz. maybe 20000 hz.I will try to build a new one 21x80 cm. and try to curve it horisontal too.To curve it horisontally,i dont get the "hot spot".
#16 |
#17 |
Awesome! Are you using shellac veneer? If it could goes down to 50Hz
, imagine completely curved magnetostat in which back wave is transmitted through tapered quarter wave waveguide and every part is steerable so that you can change directivity if necessary.
#18 |
Magnets are placed vertically or horizontally?
#19 |
#20 |
Roger Sanders , say's to stay away from curved Panels ....
http://www.youtube.com/watch?v=Vdf3V...eature=related |
| Curved sided speaker enclosures, why? | cirrus18 | Multi-Way | 52 | 10th February 2009 04:26 PM |
