Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 28th March 2009, 04:50 AM   #11
TPL-150 build thread without the horn:
Beyma tpl-150 + Lambda TD12M's
Greg
Old 30th March 2009, 07:24 PM   #12
StigErik's Avatar
I have both, but havent listened to the horn loaded TPL yet....
Here's a measurement of both without baffle. The upper curve is, obviously, the TPL150H. I would expect a little more LF extension with the TPL150H mounted in a baffle. The TPL150 sure extends a lot more in a 30-40 cm wide baffle. I'm will try to run the TPL150H as low as 800 Hz...
Old 20th August 2010, 07:39 AM   #13
Send a message via MSN to audiodesign Send a message via Skype™ to audiodesign
here my first test with this driver
Hi-End and Hi-Eff loudspeakers system 2
Old 21st August 2010, 05:15 PM   #14
I am very sceptical that these AMTweeters can handle a few watts of pink noise (third-octave bandwidth) around the lower cutoff freq without introducing easily to detect massive amounts of distortion artefacts , aka intermodulation distortion . Reason is the non-homogeneous driven surface and the nonlinear mechanical spring properties of the conductor/film-carrier combination .
Someone out there might have the balls to check that out
sorry for the bad news ...
Old 9th October 2010, 04:57 PM   #15
Here the new filter with constant impedance
Beyma 8AG/N horn or "the Viech" Cyburgs Full Range 112 12th August 2012 01:57 PM
ToneTubby 12" AlNiCo OB + Beyma CP380M Horn Project nullspace Multi-Way 6 21st April 2009 01:06 AM
-Beyma TPL 150 AMT flshzug Planars & Exotics 1 23rd June 2008 11:45 PM
Beyma CP25 Horn Tweeter Elso Kwak Multi-Way 4 1st May 2004 07:21 PM
Copyright ©1999-2013 diyAudio
