| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Planars & Exotics ESL's, planars, and alternative technologies |
Thread Tools |
#451 | |
#452 |
Alexit lacquer on 12cm cone speaker. Damping is clearly visible.
#453 |
Good result indeed ...
#454 |
CSD of a paper tweeter after treatment with hardwax oil. CSD was as messy as the FR before (didn´t save).
#455 |
#456 |
Would be even nicer if there was a software freely available.
An alternative for the DIYer could be using a realtime impedance measurement based on a noise generator like the one in Arta and move the exciter in order to find positions with well-distributed modes. |
#457 |
hello all,
here is one of the latest versions of my stereo panel http://img697.imageshack.us/img697/8061/p1111090844.jpg 8 transducers in a config inspired from Michael GERZON 2x at left & 2x at right, & 2+2 centered in the common return path response measured a 2cm, 20cm & 2m, nice work of the syncRTA the same with a "classic" RTA would be impossible http://img692.imageshack.us/img692/7...o2cm20cm2m.gif respectively green 2cm, blue 20cm, red 2m and the same with a bass-box added (YAMAHA, blue trace) http://img208.imageshack.us/img208/4440/gdpanobass.gif POL Last edited by pol_bct; 26th November 2009 at 04:56 PM. Reason: wrong typing |
#458 |
Very balanced response, congratulations.
#459 | |
a verbose description of the parameter interrelations is helpful but i feel for the effect of mass (density) there is a mistyping in your former post concerning coincidence frequency. I overlooked it, because you described the effect of mass on efficiency correctly ... I would put it this way: Effect of stiffness variation, when other parameters are kept constant ------------------------------------------------------------------- higher stiffness -> higher propagation velocity -> lower coincidence frequency higher stiffness -> higher propagation velocity -> lower modal density higher stiffness -> higher propagation velocity -> higher efficiency lower stiffness -> lower propagation velocity -> higher coincidence frequency lower stiffness -> lower propagation velocity -> higher modal density lower stiffness -> lower propagation velocity -> lower efficiency Effect of mass (density) variation, when other parameters are kept constant ------------------------------------------------------------------------- higher mass -> lower propagation velocity -> higher coincidence frequency higher mass -> lower propagation velocity -> higher modal density higher mass -> lower propagation velocity -> lower efficiency lower mass -> higher propagation velocity -> lower coincidence frequency lower mass -> higher propagation velocity -> lower modal density lower mass -> higher propagation velocity -> higher efficiency For the propagation velocity i have not found a simple english source so far, but i am shure someone will find a link in english language ... Biegewelle – Wikipedia Kind regards Last edited by LineArray; 27th November 2009 at 12:21 PM. |
#460 |
Part Express exciters attached to the window.
| Thread Tools | |
| Page generated in 0.07031393 seconds (73.41% PHP - 26.59% MySQL) with 12 queries |
