| Planars & Exotics ESL's, planars, and alternative technologies |
#411 | |
ONLY AN IDEA like lol |
#412 |
#413 |
Aerogel Ringing...
The "real" silica-based gels made from TEOS pre-cursors do actually ring audibly in bulk. Granted, it takes a piece larger than any cone thickness to hear. And, to make such a piece it takes a positive pressure drying oven to raise the pressure above the vapor pressure of the MeOH byproduct. It is dependent on teh final structure as well. Along the "sky's the limit" path, there are materials such as AlSiC (AlSiC Materials, Electronic Thermal Management System, Packaging Solutions) and Osprey Sandvik's SiAl alloys. Low weight, stiff, and machinable. But, I could not imagine the price of a piece to make, say a 15" cone. We use a 0.040x2.5x3.0" piece of AlSiC and it runs about $100/pc. But, that is made only 0.070" thick. To make a blank 4" deep and 16" square...or even round...
Regards, Aaron |
#414 |
Has anyone actually heard one of the BMR drivers?
The Q Acoustics surround speakers use a BMR driver- Rear Speakers - Q Acoustics Q-AV System Rear Speakers 'Disappearing' rear speakers for the Q-AV System.... Not too expensive to nick the drivers out of them. |
#415 |
You find my listening impressions including the BMR in post 383.
#416 |
I have BMR drivers. They are very good, well balanced loudspeakers. No complaints. Much better then more expensive Tangbands. For about 10-20$ a true star.
#417 |
Some time ago I treated a paper tweeter with two layers of hardwax oil, which is a blend of shellac, natural waxes and oils. It showed a perfect CSD after the treatment.
As I have already mentioned earlier in the thread I liked the neutrality and transparency of balsa wood, but it didnīt work due to nasty resonances. So I wondered what the hardwax oil would do with the balsa. I had only a little bit of the (expensive) hardwax oil left, so I took two 100x500x1 mm balsa stripes, one coated on one side, one uncoated for a reference. The finger snip test showed that the first layer already gives a massive improvement and after the second coating the balsa is dead like a dodo. I didnīt remove the overshoot after each application as suggested, this gives a rough surface, but saves time and money (two layers probably wouldnīt be sufficient otherwise). I am quite sure a double coating on both sides of a 3 or 4 mm balsa plywood would tame it sufficiently. I am currently not in the mood of organizing two monstrous boards, apart from the fact that the little rooms in my old house arenīt very well-suited for planar speakers. So I pass this finding over to the public. Oliver |
#418 |
#419 |
I have been following this thread, a few questions if I may? Is there a difference between the Dayton and the buyout? Parts-Express.com:*Surface Transducer Turns Virtually Anything Into A Speaker | CYBER09 stick on speaker exciter tactile transducers sound transducers nxt sonic impact 5029 5029 sound pads hidden speakers daex25 Marcato DIY projects fbr1 Parts-Express.com:*Dayton DAEX25 Sound Exciter Pair | stick on speaker exciter tactile transducers sound transducers nxt sonic impact 5029 5029 sound pads hidden speakers daex25 cyber121 Has anyone tried these? Parts-Express.com:*Sonic Splash SSP 4.0 Transducer | full range shaker ibeam tactile bass shaker transducer tactile transducer butt shaker seat shaker Gary |
#420 |
I wonder whether this stuff has other damping properties than solid steel:
http://www.lamera.se |
| Page generated in 0.12204 seconds (77.88% PHP - 22.12% MySQL) with 11 queries |
