| Planars & Exotics ESL's, planars, and alternative technologies |
#401 |
I think in this Article there is a more beautiful picture of the device:
http://www.dl0sn.de/informations/rep...adiomuseum.pdf |
#402 |
Hi There,
I'ts my first post in this thread but I've been following it with great interest. Have you come across Aerogels or as it is sometimes called Frozen Smoke? Seems like ideal material for NXT panels with its strength to mass ratio. Peter. |
#403 |
Hello Peter,
i heard about it but did not have it in the materials list up to now. I think some loudspeaker manufacturers use Aerogel (Focal e.g.) to build sandwich laminates for conventional drivers. Would an aerogel of thickness from 0.5 to 5 mm be airtight ? If not, we would possibly need a coating for low frequencies, where tightness of the panel is an issue. Then the low mass advantage compared to other materials would decrease. Also damping is an issue. Styrofoam e.g. has also low mass and high stiffness and is still airtight when cut to thin panels. But styrofoam rings like a bell and needs a damping coat IMO. Are you experienced with aerogels ? en: Aerogel - Wikipedia, the free encyclopedia ge: Aerogel – Wikipedia Kind regards Last edited by LineArray; 18th October 2009 at 09:26 PM. |
#404 |
what material do you recommend? Gatorfoam? Any better? I guess Kapa is not good... what about Dibond (0.3mm alu with foam inside)? Any other idea? Thanks, Matej |
#405 |
Why is Kapa not good?
Probably the Kapa bloc with resin coating is not so far away from the Gatorfoam. Pursonic is also Polyurethane. purSonic flat panel loudspeakers - invisible sound systems |
#406 | |
"If you don't like funerals don't kick sand in ninja's face." |
#407 |
...which we used, could be destroyed by water instantly. It was easy to grind between fingers.
tiki |
#408 |
Yeah...the capillary size in the inter-connected pore structure is so small that the water's surface tension in the small capillary crushes the glass web. Go ahead, put a piece on your tongue. If you pull it off, the surface of your tongue will come with it. (No...I did not experience that myself.) But, that is the stuff I have made/worked with before.
When people say "aerogels" I wonder what they really mean...just like "nanotechnology" that actually works on a "micro" scale.
Regards, Aaron |
#409 |
The idea was to use it in a sandwich type of structure in between two skins. Does anybody know how resonant Aerogel is? I only saw it in a granular form.
#410 | |
I believe they were originally developed for their heat insulating properties, and are still very hard to obtain, hence mucho expensivo
| Page generated in 0.12550 seconds (79.31% PHP - 20.69% MySQL) with 11 queries |
