Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 18th May 2009, 08:11 AM   #221
el`Ol is offline el`Ol  Germany
Originally posted by Ziggy
el'OL yes, it seems balsa wood is both too heavy yet soft as well - no good for NXT sound principles.
In fact 1mm balsa is not heavier than quality printing paper. Here is the CSD of the 2x0.8mm magnetostat:
Motor-based planar speakers-can it be done?
Behaves very much like a DML in the highs. I didnīt try this concept with cardboard, so i canīt say whether transparency of the balsa is worse here, too.
Old 18th May 2009, 09:43 PM   #222
jzagaja is offline jzagaja  Poland
Send a message via Skype™ to jzagaja
Aluminium decays much faster. I've tried adding the mass to monomorph brass plate and piezo plate but got contraction result to what I have wrote
Mass on piezo plate == higher modal density, higher first mode
Mass on brass plate == 6db louder
Today I phoned an old mechanical science professor who developed models for Stradivarius type violins and built prototype in 1985. There are two ways of lowering internal damping in wood: cold stretching and chemical modification.
Old 19th May 2009, 02:41 AM   #223
Ziggy is offline Ziggy  Australia
Account Disabled
Going off subject here a bit : in my last post, I accused my receiver of possible lack of highs.
I did a blind test with the help of a friend last night and we both eventually agreed that the receiver was not lacking in highs at all.
In fact, it had better highs than a homemade 300B valve amplifier with silver wired transformers !!
So, I take it all back (again!!! : ).......be careful when you evaluate or ''think'' that you are evaluating sources. It can be very tricky
Of interest also was the Pioneer's sensitivity to interconnects - vastly preferring solid core copper wire to stranded. That was not my imagination!.........fantastic highs from the panels.
This hobby is really ******* me off!!!
Old 19th May 2009, 07:43 AM   #224
According to:
Langhoff, A. (1994). Measurement of acoustic violin spectra and their interpretation using a 3D representation. Acustica, 80, 505-515.
There's no difference between a violin and DML panel.
Old 19th May 2009, 09:32 AM   #225
And if the only difference is in decay of fundamental tone and harmonic distortion then DML is well suited for anechoic recordings (even spectacular) of chord instruments worse on brass or human voice. Maybe Balanced Mode Radiator is more universal.
Old 19th May 2009, 06:55 PM   #226
http://www.diyaudio.com/forums/attac...amp=1242679394
Maybe new name: Distorted mode loudspeaker
Old 20th May 2009, 03:44 AM   #227
Account Disabled
Mor den Siur, your attached image is so small it's useless(as is your posting).............CHOLERA!!!!!!(Polish swear word)
If it attempts to show distortion figures, on/of what?........DML's vary immensely in their design and construction, size, panel material and the way they are implemented : true NXT style or the Podium Loudspeaker approach etc.
Do us all a favor and read up on this technology so that you are aware of what it's all about before posting a meaningless distortion waterfall response.
I can happily say that I have built the real thing and am listening to it every day, loving every minute of it. That does not sound like a very high distortion loudspeaker does it?
jzagaja, ....interesting. The sound of brass and voice is very natural on my panels. Piano is incredible, tympani, drums : very scary
Old 20th May 2009, 07:43 AM   #228
So are you happy with the highs again?
Old 20th May 2009, 08:50 AM   #229
Maybe I'm wrong, willing to see BMR waterfall and built a good model. What I have now is an unbalanced 10 piezo element DML. Best way is to record instrument outdoors and play through DML in a reverberant room so you can really compare the real thing. The opinion comes from prof. Farina who has auditioned Opere Sonore and NXT. I'm afraid that longer decay is considered as highly detailed speaker.
Old 20th May 2009, 10:05 AM   #230
Account Disabled
el'OL, as I have discovered and somehow tried to make evident in my last posts is that the panels are very much dependant on your source components in the audio chain.
I have recordings that have acceptable highs when played on a particular amplifier/speaker combination. The panels indicate that this same recording has highs that are totally ****. This has been confirmed with other people's systems(some had lousy highs, some had o.k highs).
The way you position the panels and the size and dampening of your listening room will affect the highs.
On occasion, I have heard CD's and FM broadcasts that had what appeared to be exaggerated highs!........go figure
So to answer your question - yes, I am satisfied with the highs. They are presented to you very differently depending on a few factors mentioned, but when it's all happening, it's great!
The panels will also wow you with the midrange also. Most of the time they sound amazing and revealing - lots of micro detail(radio announcer's studio ''atmosphere'', switching in and out of tracks, equipment noise or hum......it's all there.
In comparison with my two way compression driver/15 inch bass horn system, the panels are far more revealing. Yes........you heard that right
The horns have a tendency to make everything sound the same - especially with valve amplification.Very strange indeed - and this was first noticed when I built a Gainclone to try on the horns.
The panels like solid state, no question. Valves through the panels are far too bass flabby and the top end and midrange seems veiled over.
I don't own the Audionote Ongaku with silver wired transformers so maybe it's not a fair comparison ???
jzagaja, I'm not sure I understand your point in your last post.
When you say longer decay, do you mean reverberation or ambiance?
Either way, NXT exciters on free floating panels has the ability to produce full reverberant effects and the natural decay of instruments played in a concert hall. This is one of the best features discovered with my panel version of NXT.
If you are using 10 piezos on a panel, you will have a very fast but limited bandwidth. Reverberation mainly occurs at lower frequencies to what the piezos will go down to? Correct me if I'm wrong.
Page generated in 0.12682 seconds (80.32% PHP - 19.68% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
