PIEZO NXT type panel
el`Ol said:
I was thinking about paper reinforced with bamboo splinters. I had already phoned someone who runs a traditional paper mill. He asked for a mail with a detailed description of what I want. This was over a week ago and I still have no response, so I guess the project is dead. :bawling:
I googled how such a "Dutch" paper mill looks like and I can imagine the problem is that it is not very well suited for hard stuff like Bamboo.
Do you think I can get carbon fibers anywhere (just fibers, not a plate, etc.)?
to Ziggy
Hello,
thank you for the nice report about your experimentations
I think you wont go any further without measurements
I allready have done small tests with DML drivers
it is very easy to record a logsweep on them 5 to 10s
then to turn this logsweep into a pulse with the Farina's method.
with this single pulse you can know everything about
your transducers, amplitude response, distorsion, phase
you can have a look at the waterfall and so on.
If you think you are not far enough to examine these pulses
just post us the pulse.wav, we will do the job for you
By the way, if you do the same on your horn loudspeaker
the filtering can be examined too, and may be bettered...
http://pagesperso-orange.fr/pol.bct/exemples/DIY.htm
Thanks for all the interesting links and comments guys.
At present, I have discovered that amplification is VERY important in matching up with the panels. The amplifier needs to be around 80 watts/channel, and able to deliver decent current at low impedances.
They are not necessarily power hungry......they just need the current (as do Magnepans I suppose).
I have found that a 100 watt in to 4 ohm Kenwood 2 channel receiver that is 13 years old - ABSOLUTELY wipes the floor with many amplifiers tried here (including my monster Pioneer home theatre receiver and a few expensive high end ones :xeye: ).So the choice of amplifier can make or break the sound........go figure:xeye:
As you can imagine, I am currently experimenting on upgrade parts modifications on this Kenwood😉
Bent, please remind me of your project. It's been a while and I can't recall what you were up to.
pol_bct........thanks, I'll try to make some sense of this and use it.
el'Ol, jzagaja, tell me more about balsa'' plywood''........never seen or heard of it. Can it be purchased or made?.........is it laminated cross grain for added strength?
Shellac will harden it.........I have tried this with cardboard sheet.
Balsa or Samba can be found in every hobby shop in Poland for 4,5 EUR/m2/1mm. Typical format is 25x1000mm. Tonight will try make some laminate. I have in my mind a model made of stiff pyramid pattern excited with a long piezo custom made. In theory compression wave that is smaller than panel dimension will radiate like above coincidence peaking off axis and pyramids will convert the rest to a bending wave.
I don't see edge damping change anything. Calculated f0 and fc are slightly above 1kHz and below 5kHz respectively. Lets try to find explanation for 5kHz mode.
So, what does this mean to us all?.........what is your conclusion?
Seems to me that dampening has some positive effects.
Cutting corners..........hmmmmm???............NXT and PODIUM SOUND have both done this to improve sound due to corner interactions😕
Yesterday made round membrane and applied shellac with pumice and linseed oil as usual furniture coating. Sticked two piezos with a brass plates face to face and sticked to balsa on both side making push-pull, connected in- and out-of-phase. Response looks like one big resonance from the piezo plate itself and wood response below. Nothing interesting but don't see much change between a single arrangement and push-pull.
