| Planars & Exotics ESL's, planars, and alternative technologies |
Old technology in a new form:
http://www.atcsd.com/site/content/view/34/47/ Its response measured. The only one source is here at diyaudio ;-) |
#2 |
The LRAD is more fun, it puts all of its Watts in the audible range
2012, our time is running out. |
#3 | |
The chart has the following axis:
I am familiar with 1watt / 1 Meter term I am familiar with 2.83V / 1 Meter term, (not the same as above if impedance is not 8 ohms) Not familiar with this term. What is the norm for this measurement? Should the ideal line be flat, or is it some kind of power measurement where the ideal line should be sloping down?
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#4 |
Wikipedia: The decibel (dB) is a logarithmic unit of measurement that expresses the magnitude of a physical quantity, it is a dimensionless unit. 20uPa/V is 0dBspl - threshold of hearing.
This measurement is uncalibrated - unknown efficiency. Don't know what can be expected from heterodyne transducer - maybe typical bandpass. Some DSP is probably incorporated. Cheers, |
#5 |
Jzagaja:
Thank you. By DSP do you mean equalization? Because if the plot is not equalized, it would seem that not that much equalization is necessary up to 10kHz-it really "rolls off the table" after that. But that should be more than adequate for PA work. I also gather that the "column" they talk about is horizontal rather than vertical. Sort of a sound laser from source to point. I wonder if they have directionality charts which show how quickly the SPL goes down once you leave the area of maximum SPL.
#6 |
I had only 5 minutes and laptop. Now don't have any chance of putting hands on them. Directivity is really extreme - forget about horns. Here you hear almost nothing outside the beam.
| Eagle drillfile/gerber creation | skrodahl | Parts | 4 | 2nd December 2008 07:20 PM |
| Here is my last creation - DOCAFET class A amp! | slepro | Solid State | 43 | 26th February 2008 10:22 AM |
| Creation in English | mashaffer | Music | 0 | 15th April 2007 04:58 AM |
| My first creation | Simpleton | Tubes / Valves | 15 | 3rd September 2005 02:24 AM |
| Comments on Intelectual creation, pls | Jorge | Solid State | 29 | 30th July 2005 12:46 AM |
| Page generated in 0.09103 seconds (77.80% PHP - 22.20% MySQL) with 11 queries |
