ESl speakers - why no cabinet? - Page 2 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 3rd October 2008, 10:08 PM   #11
expert in tautology
bear's Avatar
One interesting "unbox" variation for the ESL is Infinite Baffle.
That would mean mounting the ESL into a wall. While not quite a box, it is still "a box".
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 4th October 2008, 02:57 AM   #12
bear,
an "infinite" baffle is an idea, but mounting into a wall is no good, the sound will be trapped in between the walls this will give the sound a boomy appearance. The insulation may help. Very nice amps, i am looking for two stereo amps. One to drive esl panels and one to drive the woofers. Any ideas, thinking 300wpc
bryan
Old 4th October 2008, 09:52 AM   #13
Calvin is offline Calvin  Germany
Calvin's Avatar
while in theory the rough calculation I did before suggests the need of a >200W amp for the panel, You will in praxis need much less wattage.
Itīs of more importance that the amp remains unconditionally stable under this complex load situation.
Class-D amps will be a good choice, though they often tend to a very analytical partly even a bit īcoldī sound.
jauu
Calvin
Old 4th October 2008, 04:34 PM   #14
expert in tautology
bear's Avatar
Originally posted by bshaw147
bear,
bryan
You are making an assumption that is not necessarily going to be correct.
If you open the speaker to the other side, no wall will be present.
Also, the "boomy" sonics you predict is a function of "Q" at the lower resonant frequency of the diaphragm... that may or may not be made higher depending on the specifics of the "wall cavity" that you mount the ESL in to. Also, the size of the baffle will be made very large, which will improve the LF response of the ESL substantially - a variation in Q that is undesireable might be correctable via an electronic means, if so required. But, assuming that you are making your own ESLs you can control that to some extent in the construction, for the particular application.
In terms of higher frequency effects, mounting in a standard "wall" cavity has its issues, and absorption of reflections would be very important - but assuming you have the option of modifying a wall in your home, then nothing prevents you from building out a wall intended specifically for this purpose and made appropriately for this purpose (enclosing a much larger volume) at some distance from an existing wall (like as much as 3 feet? ).
_-_-bear
_-_-bear
Old 4th October 2008, 05:30 PM   #15
bear,
I thought you were cutting out from the existing wall, yes it would help the LF response since the back and front don't mix. Thank you to Calvin for help clarifying amps and the rated wires to use.
Calvin,
One of my colleagues at school can coat thin films professional. I told him the objective is to get the charge to stick to the film and not move around in operation. We may try a SiO coating. What success have you had with coatings? Sorry for thread-jacking
bryan
Old 5th October 2008, 08:20 AM   #16
Calvin's Avatar
it seems that nearly all plasma-coated or sputtered membranes do have their problems with longtime stability in this special application. I prefer conductive polymere laqueres or the magic glue formula which are easy to be applied where it needs to be, can be controlled in conductivity, work stable over years and are optically transparent.
Too, it might be a problem to find a coater capable of sputtering thinner than 12ĩm-films.
jauu
Calvin
speakers for a wierd cabinet sky12345 Multi-Way 15 13th November 2008 03:48 PM
6x9 FR speakers - what cabinet size? Simpleton Multi-Way 3 15th December 2005 08:38 AM
Bullfrog cabinet speakers Midwestchopshop Multi-Way 0 12th November 2005 09:49 PM
cabinet builders -- will these speakers fit? Dave Jones Multi-Way 3 23rd October 2004 05:04 AM
Sealed cabinet speakers Zepper Multi-Way 3 21st May 2004 11:34 AM
Copyright Đ1999-2017 diyAudio
