| Planars & Exotics ESL's, planars, and alternative technologies |
Hi
I want to build a 70" ribbon but don't have any experience at all. Read the topic's from dhenryp and valveitude and read a lot of tips from lineSource. What would be the best mechanical motor to build with respect to acoustics and flux densety in the gap. What hapens if you make the diagram wider than 17mm (20Khz) Which thickness aluminium foil do I need with this project in metric please or what are the compromises. Mechanical construction is no problem. I already order 220 Neo N42 magnets from 40x20x10mm. So I have to start from scratch or just build the same as Valveitude or dhenryp. I can't find the ribbon from linesource. Rob |
#2 | |
Hello Rob,
Please understand that the forces involved with the size of Neo magnets you have when you add them together in a frame are tremendous..be careful and have fun. Casey
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again. |
#3 |
Hi Valveitude
I downloaded FEMM but have some difficulties to understand how I should draw. Also don't understand your drawing because it doesn't look like your build. Can you put your file online so I can see how you did it. The thickness of the foil you all talk about are always in inches? And what I read is 0.0005" the thinnest to work with without tearing it apart. Also see the drawings of the 2 optional motors with or without Iron crossbars but are there other better options. If you start all over what should you do different. Rob |
#4 | ||||
Casey
#5 |
moray james |
#6 |
Hi
I did some simulations in femm and used the ribbon calc program for spl calculations. At first I don't trust Femm if you draw the front of the magnet motor but I trust the top view drawings more. But they are also not perfect. I think that you have to start somewhere so this is it. All gaps are 20mm and magnets are 10mm x 20mm N40. Tesla in the gap from A and B are the same 0.44-0.52T from C its 0.35-0.40T. Difference between AB and C is about 0.1T I run the ribbon calc simulation and found out that the difference between 0.375T and 0.480T for a ribbon of 1,8meter long and 20mm wide and 10,5micron thick are about 2dB. So the difference between A and C in Tesla is about 30% witch yield in only 2dB. You need to double the Tesla to get 6dB more spl and if you double the ribbon you get 3dB. For acoustical reason I prefer C and B. For C front and rear are the same and for B almost except at places where the vertical bar is behind the ribbon. For construction I also prefer B because of the stiffness of the 100mm wide bar its almost impossible to bend due to the forces of the magnets so the gap difference is less along the length. I think that I build all 3 at a length of 30cm and do some acoustical measurements and decide which on it will be. Maybe I can get a gaus meter to measure the tesla in the gap of those 3 examples. Rob |
#7 | |
Hi Casey
Do you now this fore shure? I think that if you use say 1" wide magnets and a iron bar 4"x1" that you have to draw 4" wide iron in Femm. If you have 0,5"x4" iron than you have to draw a 2"wide iron in Femm. So it should be related to the wide of the magnet. What I read it draws 1mm deep. Quote:
#8 | |
You are interested in cross section area. If the real world piece is 1"x4" you have 4 square inches so you would model a 2" wide piece. If you have a piece 1/2" x 4" you have 2 square inches and would model a 1.414" wide piece. FEMM assumes the depth=width. This procedure has worked for both myself and dhenryp with very close results with the final product. Casey
#9 |
Hi Casey
I'm stubborn so I think you are wrong or maybe I am but please look at my examples. I do this in millimetres with your ribbon as an example. You use 100mmx20mm side bars and 10mmx20mm magnets 100x20=2000 correspond with 45mmx45mm 20x10=200 correspond with 14mmx14mm ratio 1:10 magnets and iron If I draw this in femm then the iron is over saturated and the strength in the middle of the gap is 0.684 Gap is 15mm wide and 240mm long. Now if I draw it with a 20mm dept (you can change this in the problem definition). I draw the magnets 10mm wide and the Iron 100mm the ratio magnet iron are still 1:10 The Iron is not nearly over saturated and the middle of the gap is 0.717 Gap 15mm wide and 240mm long If you calculate only with cross sections from the iron bar then you change the 1:10 ratio. So if you are right then I need bigger Iron bars then you did. If I'm right I can use smaller pieces of iron. I'm on holiday at the moment so I have a lot of time to simulate and think about it maybe to much. When back I try to find someone who know a lot about this subject. Over here we have a very big magnet supplier and they have the knowledge but I don't now if they want to help. Rob |
#10 |
Hi
Inspired by Valvitude i build a ribbon like he did because the well layout magnetic pad from his design. The ribbon has almost no magnetic radiation and the Iron itself is very little magnetic so the magnetic flux goes only trough the gap. The sound from it is very good with much attack and resolution. I also made some extra spacer blocks that are wider. Now I build it with a Gap of 20mm and I have blocks for a gap of 30mm and 50mm that I want to try later. This design has also major flaws. There are 2 peaks in the freq range 1 at 1khz that I can't explain and one at 8,5Khz which is the width of the ribbon behind the magnets. Both peaks are very strong and difficult to damp. So you need 2 notch filters and some damping and then you still have 2 dips at those frequencies. There was no way to get rid off the 1Khz peak. Only when I closed the back of the ribbon it was gone. I tried all different kind off baffles to find the problem with no results yet. I stop with this design because of the 1Khz peak because it's very audible. Now I going to build one with the same size but only 20mmx20mm side bars so the front and rear of the ribbon are the same. And see what the difference in spl is and sound. If I find some extra time I post the measurements of the ribbon. I run the ribbon with a transformer and a 4 Ohm resistor in series with the ribbon only and the resistor sound much better. What I also want to try is a segmented ribbon and make it about 4 Ohm Rob |
| FS: very nice RAAL "FlatFoil" ribbon tweeters {NIB }, with custom made front plate | yairf | Swap Meet | 3 | 2nd June 2009 09:25 AM |
| "Zombies" - WR125ST's with a Foster ribbon | Brisso57 | Full Range | 0 | 3rd April 2008 11:32 PM |
| Fostex 3"-5" FR or ribbon? | SemperFi | Full Range | 10 | 7th October 2007 04:30 PM |
| DIY "ribbon controller" slide potentiometer-please help with blueprints! | VvvvvV | Instruments and Amps | 4 | 21st January 2007 08:51 AM |
| Ribbon tweeter and 6.5" | jleaman | Multi-Way | 6 | 4th February 2003 05:17 AM |
| Page generated in 0.13210 seconds (82.36% PHP - 17.64% MySQL) with 11 queries |
