| Planars & Exotics ESL's, planars, and alternative technologies |
#11 |
My experience has been that if you want an ESL to be efficient which translates to playing loudly, you need to use high bias voltage. That means you need a LOT of tension on the diaphragm. That means you can't use heat shrinking.
I_F |
#12 |
High efficiency is good, but so are low resonant frequencies. You can play games with spacer and support geometry to get both low resonant frequency and good support for stability. But for a given geometry cranking up the tension can lead to other problems. If you are buildig a narrowish ESL and crank up the tension, you may have to deal with a resonant peak above where your woofer cuts over. You can use that to your advantage (as some older ML ELS's did I think) by using the resonant peak to counteract the frequency rolloff due to pressure feedback, that it's not a great solution.
But in general I_F is right, tension is good. In my experience either technique will lead to sufficient tension to be a satisfactory ESL. The technique that is best for you is the one that you are most consistent with. Sheldon |
| How do you shrink heatshrink? | Atilla | Everything Else | 26 | 23rd June 2009 02:46 PM |
| Interconnects - heatshrink v Teflon tube v tape, gauge v length | otto88 | Everything Else | 42 | 25th May 2008 07:20 AM |
| Were to find TEFLON Heatshrink??? | Guijs | Everything Else | 6 | 29th November 2005 05:00 AM |
| Techflex heatshrink | movie_fan | Parts | 1 | 25th May 2005 09:38 AM |
| Looking for flexible Heatshrink | Silver Stealth | Everything Else | 0 | 19th May 2002 01:06 PM |
| Page generated in 0.06836 seconds (73.66% PHP - 26.34% MySQL) with 10 queries |
