Peter Dicks and DDD Wave Converter - Page 3 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 22nd January 2008, 09:09 PM   #21
Default I don't think so Jan...
to the best of my recolection the Manger is a bending wave device. I do know that Manger approached Highwood Audio because our patent was in his way at the time. My old partner Paul once discribed this as a hornless horn loaded speaker. He was referring to the traveling wave in the diaphragm acting akin to a wave guide. It is a very interesting idea but it takes a lot of work to make the pony do its trick. you can look at US 4, 924, 504.
moray james
Old 22nd January 2008, 09:18 PM   #22
49 - for the 19th time!!!
c2cthomas's Avatar
Ta Moray -
I'm taking a stab at guessing that the reason for getting rid of the spider is a) reflections b) bites c) cobwebs!
DIY audio can be expensive but getting to see things go up in smoke - that's priceless!!!! ..... "whatever - call it brainfart of Mighty ZM"
Old 22nd January 2008, 09:26 PM   #23
frugal-phile(tm)
planet10's Avatar
Default Re: There is another way of doing this....
Originally posted by moray james
ues a standard voice coil and magnet assembly (best to eliminate the spider though). Connect the top of the voice coil to a tensioned plastic diaphragm install some form of dust cap. Now when you pulse the diaphragm a wave front is set in motion forward from the dust cap while at the same time the voice coil imparts a annular wave form which spreads out across the plastic diaphragm. The leading edges of theses two acoustical events are linked and in sink with each other. The end result is a spherical (reasonable fax) wavefront generated from a flat plastic diaphragm. It is the old ripple in a pond. Works like a charm if you juggle it properly. If any one wants to complain that it could not can not will not work because of so many reasons then explain how that german blathaller jig is selling for silly money. Give it a try before you say it wont because it will.
Moray,
Isn't this essentially the same tech you guys developed for the flat-panel speaker?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd January 2008, 09:44 PM   #24
Default Yes and Yes...
just another way of doing much the same thing a walsh cone does.
moray james
Old 22nd April 2008, 09:17 AM   #25
jan.didden's Avatar
Just wanted to let you know that Peter Dicks has updated the technical info on his driver recently. It's now more tech, less marketing blurb.
The pertinent page on the German Physiks website starts here:
http://www.german-physiks.com/techno...dd-driver.html
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 22nd April 2008, 11:33 AM   #26
Some 25 years ago I read an university thesis on a travelling wave loudspeaker. It was composed of a flat honeycomb structure excited by voice coils at the left and right edges (in stereo). I was said the acoustic waves were travelling in lateral direction across the length of the radiator (left and right channel in opposite direction), and radiated from the whole surface at a defined angle (not perpendicular). There was some dampening at the edges to absorb the waves at the end of their travel. Does the Wave Converter work on a similar principle?
Old 22nd April 2008, 01:55 PM   #27
jan.didden's Avatar
As I said, there is now much more info on the website. Note also that the DDD actually has 4 regions of fundamentally different operation, depending on the freq range of the signal. It is better explained there then I can repeat here.
Jan Didden
Full wave or half wave rectification help! HaLo6 Digital Line Level 1 26th March 2009 01:14 AM
Sine wave - Square & Triangle wave generator using Transistors / OP-Amps lineup Solid State 20 9th October 2006 12:15 AM
Microphone turns triangle wave into square wave? Circlotron Analogue Source 18 25th January 2003 06:44 AM
Copyright 1999-2017 diyAudio
