| Planars & Exotics ESL's, planars, and alternative technologies |
#21 | |
Have you thought of using a tapered triangular prism, wider at the base than the top? Perhaps this would increase bass output while still allowing decent high frequency response.
"Part of the reason a poot into a toilet bowl sounds the way it does is because of phase shift." -Andrew Eckhardt |
#22 |
Certified means that NCEE Labs is a certified testing lab. They have certified that the Planot design works. That means that the response of the third Planot prototype was measured in a 10 meter semi-anechoic chamber.
It was found to be linear in all microphone positions. It was measured with an A-weighting. This test set up was intended only to certify that the design works as claimed. It was not intended to test the performance limits of the design but to establish that the basic design parameters were satisfied. Further tests will be carried out on future prototypes. Test results can be sent to qualified individuals and companies that sign and return my nondisclosure agreement. I felt this was necessary to establish credibility. Many who are schooled in the physics of sound were incredulous after reading the description of the Planot speaker. They believed it would not produce much if any sound. Fortunately the opposite is the case. I can't imagine enduring all of the barbs that I have and doing all of the work that I have done for a lark. There is much work that remains to be done. It is heartening to receive the support that I have received from Discussion Forums such as this. I hope that there is some way to repay the support in the future. John |
#23 | ||
Could you share more information on the acoustic measuring capabilities of NCEE Labs? I'm sure that many here, including myself, dream of some day building and selling speaker systems of their own designs. To which, a means for professional measurement and certification in an acoustic semi-anechoic (half-space) chamber that is cost effective enough to use even on prototypes is very alluring. The problem is, I can't find any information regarding NCEE Lab's capabilities in these respects. I'm a reader, when I want to know something, I've no problem sitting down and going through a couple hundred pages of material or so. However, everything I've found to read regarding NCEE Labs' capabilities make no mention of acoustic measurements of loudspeaker systems or the like. In fact, most everything they do and are capable of testing focus on electromagnetic interference (production of and resistance to) with some further testing with regards to environmental factors and general safety. Their A2LA certification, which is what gives them the authority (and limits it) to certify products, itself makes only mention of EMC/EMI and the environmental/safety testing. Odd. So, I figured any information regarding their acoustic testing facilities would be related to the 10 meter semi-anechoic chamber you mention. Well, dang it, all I can find NCEE Labs mentioning as an anechoic chamber is one devoted purely to RF (EMI/EMC) testing, not acoustic. Quote:
Now, surely this can't be right. This means that the Planot speakers are only certified to be in compliance with FCC Part 15 rules and possibly safe from self-destruction or are even salt-spray resistant. While it's nice to know a set of speakers won't cause RF interference in the clock radio the next room over, I'm sure most here are more interested in measurement and certification of the audio output performance of a speaker design. So, could you share some more information about the acoustic measurement facilities of NCEE Labs for future reference? I would like to learn more as their website and all the others I found regarding their certification are mum about audio. Surely this information won't violate your rarely paralleled secrecy about the performance of your speaker. Thanks, - JP |
#24 | |
A little harsh to an knowledgeable audio consumer who's handing out free advice don't you think? What strikes me as odd is how defensive you are John. Obviously with a design such as this you would have expected that there would be more doubters and nay sayers than believers. The funny thing is that Bear and many others here never said that they doubted, but instead brought up problems that they foresaw with the design. Now obviously these are problems you've foreseen and encountered, and as such I would expect the proper response to explain how you've dealt with them, not to attack those who see the problems as well. After all, wouldn't that be why they are bringing up the problems and issues inherent to your design, to see how you've dealt with them? After all John, I can guarantee there are many people far more knowledgeable than you or I on this message board... -Justin "despotic931" |
#25 |
Justin: Mr. Bear's comments defiantly had an edge. My reply was acidic. Mr. Bear, I saw his Web site, is obviously a sophisticated "poster" here. I appreciate his comments but I was wanting a question. All of what he had to say appeared to me as rhetoric. Don't assume that you know what I know. With that said I appreciate your comments and will act accordingly as I don't wish to insult anyone's intelligence or motives. I would like to stimulate discussion. Some of the issues bear raises are beyond my ability to measure. I have contacted a "super computer center" about modeling the behavior of the Planot diaphragm. Unfortunately I have not been able to receive a commitment from them. I have explained that there is very serious science to be done here. When asked to I identified a modeling software package that would be able to do the modeling. It turned out that they have an academic license for the software! The center is the Holland Center for Computing in Omaha Nebraska--where I live. It is on the campus of the University of Nebraska at Omaha. Maybe if I could instigate an e-mail campaign I could convince them that there is a lot of interest in doing this science. Guerilla supercomputer science. Please e-mail mfurtney@hollandcomputingcenter.com with comments. John |
#26 |
The NCEE Lab is what it is. It was close at hand. They did not charge me a small fortune. They are nice people. They are a not for profit organization that has no affiliation with Planot, LLC. My goal was to have an outside and non-interested organization certify that it WORKS. My goal was not to measure performance. (Especially this proof of concept prototype.)
If you are a verifiable authentic audio company and sign and return my nondisclosure agreement and pay me a handling fee I'll send you a bunch of test results. You probably won't be too excited about that. When P4 is built I will have it tested by a lab certified to do acoustic testing and probably post test results. I believe specifications do not tell you how a speaker is going to sound. This is why I place more importance on reviews and testimonials. I will be posting more on my Web site real soon. John |
#27 |
I think I speak for many here, in saying that it would be nice if you could, please, share some performance information. We're all interested in your idea, and this is considered to be an open forum where ideas, results etc are shared. Moreover, few if any of us will have the opportunity to listen to your prototypes.
Regards, Ed |
#28 | |
Take this as you like, but I've made a career out of inventing and licensing. My inventions range from aerospace materials and structures to game controllers to beverage packaging. They are produced by the billions of units and used all over the world. I've started and sold off several companies. So with that in mind, when I tell you that you're not on a path that's likely to pay off, please take it as constructive criticism.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#29 | |
John |
#30 |
I notice that the USPTO has no applications or patents for you. That's a problem right there- you've put the idea into the public domain, so that's pretty much foreclosed to you.
In general: 1. Do patent searching- is your idea actually new? Does someone else have a patent that would prevent a potential licensee from practicing your invention? 2. Do not do public disclosure until you've got a patent application filed. Nolo Press has some excellent books and forms which will guide you through the process. 3. Once you have that application in, publicize like crazy. NDAs are nice when there's know-how extending beyond the patent app which needs to be disclosed, but no-one serious is going to sign an NDA unless you've already established some credibility with a patent app or an already-impressive track record. Too much liability. 4. No-one serious is going to pay you a fee to look at test results. 5. No-one serious is going to come to you; you have to aggressively and persistently go to them. 6. Have a VERY clear idea of who your targets are, how you will sell them your idea, and why they would want to buy it. There, I saved you a dime.
| Metal Oxide vs flamme proof vs metal film | ostie01 | Parts | 28 | 26th June 2006 06:38 AM |
| looking for sloped/phase aligned/triangle shaped speakers | Hybrid fourdoor | Multi-Way | 3 | 16th October 2005 10:28 PM |
| Triangle-pyramid shaped speakers | kneadle | Multi-Way | 30 | 25th December 2002 03:07 PM |
| Page generated in 0.13465 seconds (86.10% PHP - 13.90% MySQL) with 11 queries |
