ESL Diaphragm coating - Page 79 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 27th June 2013, 04:44 PM   #781
audioquestM-40's Avatar
Originally Posted by Legis View Post
Is elvamide real PITA to dissolve into ethanol, am I doing something wrong?
I bought the Elvamide from here: Electrostatic Speaker Conductive Coating Elvamide 120g | eBay
That stuff is crap and I doubt it is Elvamide at all. I bought the exact same stuff. I made an electric motor stir device and did mine for 4 hours and zero of it dissolved
I should add though, the seller is first rate and refunded me the cost.
Krell KST100, Edge M4, Bryston .5b, Audio Research LS2B, OPPO 103, Moon 300d, MF A3.24, Oracle Alexandria SAE mc cart, Jasmine LP 2.0se phono, Martin Logan reQuest
Old 28th June 2013, 09:06 AM   #782
SM7UYJ is offline SM7UYJ  Sweden
SM7UYJ's Avatar
I have bought from the same seller and after that got samples directly from DuPont - have had no trouble to dissole the stuff!
Follow the instructions and heat is very important-takes a while but dissolves perfectly!
The probability of someone watching you is proportional to the stupidity of your action.
- A. Kindsvater
Old 28th June 2013, 12:20 PM   #783
The stuff I got was NFG. I followed the instructions for solvent and heat with automated stirring and after 4 hours no change.
Old 29th June 2013, 08:54 AM   #784
alexberg's Avatar
DUH!!!????
Elvamide is filed under "thread bonding" on the official web site... Go to craftman's store and buy some. Below is posted picture for one of the brands. Look at the bottom right corner. What do you read? Right! "100% Polyamide". 3 micron layer on 1 sq meter contains 3 milliliters of nylon OR about 3 grams. This won't make you broke...
DO not wanna buy? Try to nag from the address on Dupont Canada web site
And Read This Fine Manual about the solvents: http://www2.dupont.com/Plastics/en_U...ng/302061a.pdf
Old 29th June 2013, 10:05 AM   #785
Legis is offline Legis  Finland
Legis's Avatar
I have come to the same conclusion, the patch I got from that ebay seller is not real Elvamide. Luckily I managed to get 1kg sample of Elvamide from Dupont.
Old 29th June 2013, 10:21 AM   #786
CharlieM's Avatar
You can't go wrong with Licron Crystal. I thought it was unobtainium in Canada, but maybe not:
https://shop.eis-inc.com/sap(bD1lbiZ...od_nbr=1756-8S
EIS - Canada
6 Melanie Dr., Brampton, Ontario, L6T 4K9
Tel: 800-538-1578 | Toll-Free: 800-538-1578
Canada
Old 29th June 2013, 01:51 PM   #787
Originally Posted by alexberg View Post
DUH!!!????
I emailed Dupont, we went back and forth a few times. They said they'd try to send some, never did. I've read through the Dupont site and it's material specs but I don't hang out in the fabric and sewing isle much, so I've never seen this thread bonding material pic you've attached but I'll have a look sometime.
Old 30th June 2013, 04:54 AM   #788
DeltaStar's Avatar
Licron Spray 1756S is available in Canada, I picked mine up for 38 a can from Acklands, heard they raised the price though, will check out tuesday and find out the reason why. Al
Old 30th June 2013, 03:59 PM   #789
Yes, I got some last week thanks for that tip a while ago. It's $51 with shipping.
Old 29th January 2014, 03:52 AM   #790
Default back to basics
Getting back to basics.
In applying the coating. If using spray on licron, you only want the center part of the membrane coated with licron, with a small tab for connection to the bias supply wire.
And need to avoid getting the licron near the (or on the spacers). What do you use to mask off the area of the membrane that you don't want treated?
Thanks,
Paul
Diaphragm coating Bazukaz Planars & Exotics 24 9th October 2016 10:41 AM
ESL Diaphragm Coating - HELP GlidingDutchman Planars & Exotics 12 11th October 2014 08:04 PM
PCB coating rs1026 Parts 10 2nd December 2011 11:08 PM
Help with diaphragm coating furly Planars & Exotics 6 17th January 2006 08:23 PM
ESL diaphragm coating I_Forgot Planars & Exotics 58 4th April 2005 05:54 AM
Copyright 1999-2017 diyAudio
