ESL Diaphragm coating - Page 58 - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 13th July 2012, 01:37 PM   #571
WrineX is offline WrineX  Netherlands
WrineX's Avatar
Hehe there must be a reseller in Europe can't believe this
Old 14th July 2012, 03:35 AM   #572
You can use a graphite charge ring as well.
I have been using aluminium tape and I never had a problem with my panels of 9 years old, You just scuff it up real good with some steel wool and your good.
jer
Old 14th July 2012, 05:44 AM   #573
chinsettawong's Avatar
I use this computer screen cleaning gel for coating the diaphragm on my electrostatic headphones and it works great.
I'm sure you can find something similar there too.
Wachara C.
Old 14th July 2012, 02:50 PM   #574
Legis is offline Legis  Finland
Legis's Avatar
Thanks, I found couple antistatic gels for LCD screens, might test them.
How thick and untransparent is the layer of licron crystal when applied undiluted with a sponge? I found a local source, but would have to pay ~65 dollars for one bottle. That's quite much but if the stuff is good, then it's worth it.
Old 14th July 2012, 05:29 PM   #575
CharlieM once told that it was only a few microns thick.
I can't seem to get a reliable reading using only my micrometer.
I can with the regular formula Licron.
It is pretty transparent otherwise yet only very slightly cloudy, But it is hardly noticeable when looking at it through the stators.
Jer
Old 14th July 2012, 07:41 PM   #576
tyu is offline tyu  United States
Thanks for the info...vary cool...keep it comeing
Old 16th July 2012, 12:10 AM   #577
It's correct that Audiostatic used copper foil tape, but it's unnecessary for transmitting low current high voltage. You could use for example the tape used on windows for burglar alarm systems.
A tip to check if you have high voltage leakage: Disconnect the high voltage PSU from the outlet... If you speakers can continue to play for several minutes without a volume drop then you know your high voltage part including membrane coating is okay.
Old 16th July 2012, 03:04 AM   #578
alexberg's Avatar
All you need is to find microscope, make the cut through the coated tape at 45 degree angle and have a look at the cut. You will see the thickness of the coating it terms of substrate thickness.
Old 16th July 2012, 12:09 PM   #579
Legis's Avatar
^Thaks for the tip.
Licron crystal is ordered. I found the local distributor (in Finland) via "find distributor" application on the Techspray's website, bottom right corner: TECHSPRAY
Old 16th July 2012, 04:41 PM   #580
CharlieM's Avatar
The Licron Cyrystal comes in an aerosol spray can. One wet spray coat looks thick initially but it's 98% solvents so it dries to about 2 microns. I can't say how thick it would be if applied with a sponge.
Diaphragm coating Bazukaz Planars & Exotics 24 9th October 2016 11:41 AM
ESL Diaphragm Coating - HELP GlidingDutchman Planars & Exotics 12 11th October 2014 09:04 PM
PCB coating rs1026 Parts 10 3rd December 2011 12:08 AM
Help with diaphragm coating furly Planars & Exotics 6 17th January 2006 09:23 PM
ESL diaphragm coating I_Forgot Planars & Exotics 58 4th April 2005 06:54 AM
Copyright 1999-2017 diyAudio
