Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 26th February 2012, 01:30 AM   #551
You might want to see if he can get it in bulk.
1 gal. is about the price of 4 cans.
I have not yet tried the bulk version myself as I got my cans as free samples from a local techspray dealer.
Good Luck !!
jer
Old 7th May 2012, 09:19 AM   #552
We may be seeing a new type of coating soon !!
Scientists Invent Graphene for Wearable Electronics, Mirrors
jer
Old 12th July 2012, 01:31 PM   #553
Legis is offline Legis  Finland
Legis's Avatar
My panel seems to have dropped efficiency 5-7dB in a week after I applied the antistatic spray. I buffed a very slightly layer, did I perhaps apply too little of it? The stuff is designed to act as a antistatic vinyl polish and is used for plastics.
The neon lamp flash rate has also decreased considerably, to about half of the initial rate. Now it blinks every 2-3 seconds with 4,7kV bias. Right at the start it was more like every second.
I don't think the air humidity has changed much (my meter has been constantly at 50-55%) and even though it had I would not think the effect to be so dramatic...
I'm thinking if i should do some R&D with mixing this antistatic spray with high polish car wax I have and see how it works. Apply a layer, let it dry and then buff most of it away it like normally with car wax, and then live happily ever after? Anybody tried this combo?
I also have a sample bottle of ER audio's coating, that seems to have at least ink in it as it's blue, I could also apply this to the mix just a tiny portion... I'd like the membrane to stay completely transparent.
Legis
Old 12th July 2012, 02:26 PM   #554
WrineX is offline WrineX  Netherlands
Yeah i used some antistatic spray to and really it will drop even further , and be gone after a while. same goes for the glue on water base, looks promissing but wil decrease performance after a while. believe me i did my audiostatics 6 times with both options and was disapointed after few weeks.
i used licron, but i sprayed all in a bottle deluted it with alcohol. like 1/2 then used a sponge to aplly , use a paint brush, or even beter a spray gun. but you need to know how to use one. i got best result with the spponge.
Put it on the mylar and then use the sponge to get an even layer. still going strong , an by far the best efficiency i ever got. but be really carefull with it ,,use tape to mask what you dont want to conduct !!! or you get leakage really easy. and it will not go away.
Old 12th July 2012, 02:31 PM   #555
Btw you could use the ink just a tiny bit , and it will look transparant when not much used. but the ink is gone be the only working factor, using it with the antistatic is usless. antistatic will stop working and the ink does not but question is it enough.
could use the water based glue ith water and the ink so it will stick, but i recon you have to use more ink and they wont be transparant any more.
i say get a bottle of licron, delute it as you like, the more deluted the higher resistance and also transparancy increases.
the spray cans are pricey like 40$ but deluted its like 20$ and you could do like 6 fullrange esl's or maybe even more cause i spoiled quite allot when trying to use a spray gun
Old 12th July 2012, 03:15 PM   #556
Legis's Avatar
Hi wrinex,
I quess I will have to try licron if this does not work out. I'm gonna try 50:50 mix of the car wax and antistatic vinyl polish spray.
Where does one get licron from Europe in a canister (not spray)? What alcohol did you use to dilute it, ethanol or something else? Can one use paint thinner to diluting?
Old 12th July 2012, 04:05 PM   #557
well i used a bottle of Alcohol Ketonatus 96% , you could try to begin witg 1-3 alcohol 2-3 licron and go up from there.
source of licron spray
WEIDINGER - Antistatik-Überzug / 278 ml
just spray in a glass container. and then delute and shake.
weird enough the postage is almost 7 euro cheaper when you buy 2.
51,00 € for one incl postage
77,00 € for two incl postage
Old 12th July 2012, 04:49 PM   #558
chinsettawong's Avatar
Neon lamp flash rate decreasing is actually a good sign. The slower it blinks means the better the panel is holding its charge. Are you sure that the lose of sensitivity is due to the coating?
Wachara C.
Old 12th July 2012, 05:00 PM   #559
Legis's Avatar
Wachara C.
I cannot think of any other reason. I applied the spray under and over the charge ring that covers the whole perimeter. HV lead is soldered to the ring. Charge ring's glue is also conductive.
The antistatic spray + car wax failed terribly, the sensitivity decreased 5dB more.
I quess I have to order licron.
By the way does mylar handle solvents well if I'm gonna clean the membrane from the antistatic spray and car wax with paint thinner? I have tried it on sample piece and have not seen any detrimental effect.
Old 12th July 2012, 05:01 PM   #560
it kind of depends, if there was leakage somewhere and the rate is going down this could because of two reasons, either leakage is less then before, or coating is not conducting as is should. for instane only half of the panel or resistance is way to high. or the coating is going bad near the point where it leaked in the first place.
so les blinks does not mean it workes beter , ive fooled myself with this in the begining, really nice steady slow blinking but no sound...
thats why clean al the pannels verry carefully and mask with tape before aplying new coating.
PCB coating rs1026 Parts 10 2nd December 2011 11:08 PM
ESL Diaphragm Coating - HELP GlidingDutchman Planars & Exotics 9 14th March 2008 10:53 AM
Help with diaphragm coating furly Planars & Exotics 6 17th January 2006 08:23 PM
Diaphragm coating Bazukaz Planars & Exotics 9 15th January 2006 07:27 PM
ESL diaphragm coating I_Forgot Planars & Exotics 58 4th April 2005 05:54 AM
Copyright ©1999-2013 diyAudio
