| Planars & Exotics ESL's, planars, and alternative technologies |
The formula for the capacitance of an ESL is given by:
C = (8.85E-12 x A) / d Where C is in Farads, A in square meters and d in meters. My question is, what should "d" be? The D/S spacing? but the diaphragm is at constant charge. The audio signal is applied to the stators. Thus should not "d" be the distance between the stators? The books I have seen use D/S, but that seems wrong to me. Is there an explanation why D/S should be used? |
#2 |
An ESL is a very complex load, i think that formula is just a good approximation.
Capacitance increases with area and decreases with spacing. But the spacing is always changing during operation. Edit: There would be stator/stator capacitance also but it would be small and most likely insignificant. |
#3 |
basically it dosen´t matter which distance You choose! The formula gives an idea about the capacitance value under nosignal conditions. In a symmetrical ESL the distance between stator-stator is twice the distance stator-membrane. The capacitance between stator-stator is one half of that of stator-membrane. This is equal to a series connection of two identical caps....the value is halved. But since the diapgragm is usually coated with a high ohmic value material, it is difficult to measure the stator-diaphragm capacitance. The low-impedance stators You can easily measure. This value is more interesting because it is the one that the amplifier sees (through the transformer). jauu Calvin |
#4 |
> This value is more interesting because it is the one > that the amplifier sees (through the transformer). Exactly, that is why I was surprised to see the D/S capacitance used in the books. (Sanders, Wagner, Fikier) Have you ever compared the measured and calculated capacitances of your speakers? |
#5 |
Yes,odf course For the sheet metal stators I use the st-st-capacitance is nearly the same as calculated. jauu Calvin |
| crossover calculation | conket | Multi-Way | 3 | 11th May 2009 10:54 PM |
| Max SPL calculation? | Ignite | Multi-Way | 17 | 9th April 2007 08:38 AM |
| Calculation | aguantesoda | Solid State | 5 | 31st December 2006 09:02 PM |
| Parametric Q Calculation--help, please | tocs100 | Multi-Way | 3 | 2nd January 2006 12:21 PM |
| Heatsink calculation | wuffwaff | Pass Labs | 2 | 24th December 2002 12:39 PM |
| Page generated in 0.07839 seconds (76.22% PHP - 23.78% MySQL) with 10 queries |
