Drop Ceiling as ESL Encolosure? - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 14th September 2007, 10:22 PM   #1
Default Drop Ceiling as ESL Encolosure?
Hello all, do you think a drop ceiling would do as an enclosure for a pair of electrostatic loudspeakers? It has 200 cubic feet.
Old 20th September 2007, 11:17 PM   #2
Well yes, maybe...but does this mean you are mounting the esl panels horizontal?
Just conjecture of course; Doesn't that mounting strongly bias the diaphragm toward one stator, and wouldn't that limit spl or maybe even short the diaphragm to the stator????
Diaphragms agains stators with the HV powered up is likely to burn some rather spectacular holes in things.
Cyclotronguy
Old 21st September 2007, 01:18 AM   #3
I was going to build rectangular pipe off the back of the ESL and into the ceiling. I would line the pipes with 4" thick acoustic foam and staple insulation around inside the drop ceiling. By the way they will be pretty big ESL's, 80"x34".
Old 23rd September 2007, 07:33 PM   #4
expert in tautology
bear's Avatar
Probably pointless, and wasted effort.
What you end up with is a LF a sort of strange transmission line/IB setup. Better to just go with one or the other concept, and probably skip the ceiling connection. But at least see it that way.
The 4" thick stuff, if it is the right stuff will absorb a serious amount of energy above some frequency that is likely <500Hz and >125Hz depending on the material and implementation (distances etc...). So, that ends up making the back enclosure look like an IB above those freqs. The only thing left is the LF response.
Decide how to deal with that.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th September 2007, 12:51 AM   #5
So will leave a part of the back side unenclosed to save the HF? A third octave equalizer should be able to flatten it out.
Old 27th September 2007, 07:41 PM   #6
expert in tautology
bear's Avatar
Eh?
Not sure what you mean "save the HF"??
I said that you should decide on the type of enclosure or lack thereof as part of the design.
There is a diff between a Labrynth and and Infinite Baffle (IB) - both VERY different than dipole (open back).
_-_-bear
_-_-bear
new in-ceiling spk jam-huang Multi-Way 5 23rd December 2007 06:41 AM
BIB and ceiling height Mr.Mekulic Full Range 7 21st November 2007 07:58 PM
Which cheap ceiling speakers are OB fun? freddi Full Range 0 9th January 2007 07:58 PM
$2,000,000.00 ceiling speaker rcavictim Multi-Way 15 26th November 2005 02:38 PM
Copyright 1999-2017 diyAudio
