My DIY planar speaker! - diyAudio
Go Back   Home > Forums > Loudspeakers > Planars & Exotics
Planars & Exotics ESL's, planars, and alternative technologies
Old 6th February 2003, 07:40 PM   #1
Default My DIY planar speaker!
I have some pics up on my website showing my DIY planar speaker.
www.purifiedaudio.bravepages.com/speaker.htm
The sound is much better than I thought it would be. The technology is similar to a Maggie.
I was shooting for Freq Resp of 200 to 10K with decent sensitivity and impedance.
The system is 70 to 12K, 6 ohms, ~80dB @ 1W. It's been a fun project, so far. Cost is under $40 for this unit.
I would like to hear any comments or suggestions.
Matt
Old 6th February 2003, 08:20 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
How exactly does it work? I'm guessing the magnetic field around wires repels them, producing sound? (Railgun effect, if you will ) Wouldn't that require a DC bias..?..
Tim
Old 6th February 2003, 08:39 PM   #3
Default how it works
The magnets and wire are arranged as below:
N= North pole of magnet facing you
S= South pole of maginet facing you
U = wire going up
D = wire going down
N U S D N
N U S D N
N U S D N
N U S D N
N U S D N
N U S D N
BOTTOM
The wire runs up from the bottom between the N (on the left) and S (middle) columns, then arcs over to the next column and goes down between the S (middle) and N (on the right).
(There are more columns than this, but this is just for illustration.)
The clear membrane has the wires attached in the manner described (poorly) above. The current through the wire makes a magnetic field. This magnetic field interacts with the stationary magents. The attraction and repulsion of these two Magnetic fields vibrates the wires, which move the membrane.
Hope this helps,
Matt
Old 6th February 2003, 09:48 PM   #4
Sch3mat1c's Avatar
I take it the membrane (diaphragm) is connected to the wires, and since the wire doubles back on itself, and the static magnetic field is similarly flipped, so the wire, given a direction of current, is deflected in the same direction across its length.
Nice bit of magnetophysics going on
Tim
Old 9th February 2003, 07:24 PM   #5
You're correct, Tim.
Old 1st July 2010, 09:29 AM   #6
Default Planars
Nothing has been done since?
I am curious..
Full range planar speaker using neo magnets JAMESBOS Planars & Exotics 335 5th April 2014 01:28 PM
Anybody seen this type of planar speaker? WrineX Planars & Exotics 18 20th August 2012 02:36 AM
diy planar... again ionomolo Planars & Exotics 2 16th March 2009 12:42 PM
need help picking a planar speaker lochness Multi-Way 5 30th May 2007 08:42 AM
planar 25 vs planar 3 GAK Analogue Source 2 30th January 2004 03:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
