| Planars & Exotics ESL's, planars, and alternative technologies |
#1 | |
![]() http://www.wraithspeakers.com/pg2.html What???? |
#2 |
Like audio specs everywhere, you have to read between the lines- what they don't say tells you more than what they do say. 10 Hz response from a 36 x 24" ESL? Sure, if you run it at very low volume, and put the test mic right up against the speaker.
The frequency response specs do not say what SPL is achievable at the low end. If you have any ESLs, try this experiment- put your ear right up against the speaker and see how low the freq response goes. Now back up to a normal listening distance and see what happens to that low freq output. There are no mysterious mysteries here. Oh yeah, patents.... the web page doesn't have any numbers, but I'm guessing they involve the design- i.e. the appearance, of the speakers, not some special technology that allows them too reproduce very low freqs at high volume levels. I_F |
#3 |
You can surmise from the limited specs given that it is -3db @ 15hz. That still doesn't give any hint as to how loud it will play at that frequency. The efficiency isn't anything to brag about either at 88dB (probably 2.83v/1m).
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#4 |
These seem to be relevant:
Electrolytic loudspeaker assembly US6819769 2004-11-16 ZIMMERMANN CLAUS and US5392358 1995-02-21 DRIVER MICHAEL L Regards James
The border between the Real and the unreal is not fixed, but just marks the last place where rival gangs of shamans fought each other to a standstill. Robert Anton Wilson |
#5 |
typical fantasy-specs ![]() I tried to figure out if there is just one novelty in the Zimmermann patent. I didn´t find it, apart from the misleading word ´electrolytic´. Anyone more successfull? Btw. The same is with a later ´Acoustaguard´ patent of Zimmermann. This guy seems to write rather non-value patents with as many words and repititions as possible to fool the patent-office into granting him patents that he can use for marketing purposes. jauu Calvin |
#6 |
110dB @ 30Hz is good for an electrostatic? It cant be 110dB next to the panel and not still be pretty loud.
| Using electrostatic CRT's | Simpleton | Parts | 1 | 22nd June 2005 10:08 PM |
| Wraith ESL panels | Sheriff | Planars & Exotics | 0 | 14th August 2004 05:37 PM |
| Electrostatic's and Sensitivity | fr0st | Planars & Exotics | 11 | 3rd February 2004 08:27 PM |
| Electrostatic Speakers & Amp | ralph-bway | Multi-Way | 28 | 6th July 2003 06:43 PM |
| Electrostatic Shields | Gumboots | Tubes / Valves | 5 | 21st August 2002 02:48 AM |
| Page generated in 0.10070 seconds (72.78% PHP - 27.22% MySQL) with 10 queries |
