| Planars & Exotics ESL's, planars, and alternative technologies |
Hello, I am new to this forum and have a very easy question for everyone, (except for myself). I have a couple of acoustat mb-131 interfaces that I purchased off ebay. I wanted to mate them with some Martin Logan Request Panels that I have stored away. there are 3 wires that come out of the panel (blue, black and red i believe), and 2 binding posts in the interface, (white and blue). Can anyone tell me what colors connect to what? I know its a simple question, but I would hate to burn up a panel just trying to figure it out. Thanks
#2 |
If so they will not. Those Acoustat interfaces are ment for a hybrid that has a dynamic bass driver. If you are aware of this then everything is ok. Better to say and make sure. On acoustat panels the three wires are color coded white, blue and red (but it usually looks pink). The white and blue are your stators and the red is your high voltage connection. You can easily see on the circuit board in the Acoustat interface where these wires go as they are normally marked with stick on colored dots (white & blue) whike the HT connects via a small pin connector (female on the board). It has been some time since I wired up a Martin Logan. You should be able to carefully peel back the insulating tape (at the bottom corner) to see which wires are which on the Logan panels. As long as you wire the two panels the same (referring to stator polarity) it won't make a difference. You can then listen and switch polarity of your speaker connections to determine which way sounds best. Then if the best sounding way has the speaker terminal connections in reverse just switch the internal connections around inside both units. That should get you there.
moray james |
#3 |
excellent information. Appreciate it very much.
#4 |
Hi
On the martin logan panels Blue is front stator, black is rear and red is high voltage. Martin |
| Martin Logan CLS Panel Refurb | GlidingDutchman | Planars & Exotics | 0 | 10th March 2008 02:26 PM |
| martin logan's | dsiroky | Pass Labs | 17 | 16th April 2007 10:13 AM |
| acoustat panel (without interface) | etalon90 | Swap Meet | 6 | 13th July 2006 01:00 AM |
| Martin Logan Panel Project????? | Dominick22 | Planars & Exotics | 8 | 16th November 2005 01:27 PM |
| martin logan csl | flodge | Planars & Exotics | 12 | 13th November 2005 02:59 PM |
| Page generated in 0.08472 seconds (72.53% PHP - 27.47% MySQL) with 10 queries |
