diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Planars & Exotics (http://www.diyaudio.com/forums/planars-and-exotics/)
-   -   ribbon tweeter (http://www.diyaudio.com/forums/planars-and-exotics/107068-ribbon-tweeter.html)
Andy Bartha 17th August 2007 07:43 PM
ribbon tweeter
I have a unkown manufacturer blown ribbon tweeter out of a Audio Mecca Megatrend speaker from the mid 8O's. Does anyone know made this tweeter or point me to someone who can repair ribbon tweeters.
drumheadz 18th August 2007 10:15 AM
Could you post a pic? Cheerz
Andy Bartha 20th August 2007 07:12 PM
2 Attachment(s)
picture of the Ribbon tweeter
tinitus 20th August 2007 08:11 PM
Gamma is an eastern europe copi of the famous Decca, looks like that - I know the inside of a Gamma, but not the Decca
Magnets may be cobolt or even alnico, I dont know - front poleplate could be special too
[Ro]Sharky 20th August 2007 08:14 PM
i think u have the same model as i do
http://i14.tinypic.com/62yczo2.jpg
Mine are bulgarian tweeters made after goodmans specifications.
The foil is made out of plastic with a metal coating.
I don't know how u can build something like that.
You can try cutting a piece of aluminium foil and mount it between the two screws.
You will have to make sure that the impedance of the repaired tweeter has reasonable values.
Put a resistor (10ohm) in series with the tweeter, and connect them at a sinusoidal voltage source from 2kHz to 20kHz.
Check the voltage on the resistor and compare it with the voltage on the tweeter. The ratio between them is equal with the ratio of the resistor's and the tweeters impedance value. It should be greater than 0.3. Otherwise your amplifier will see a very low impedance and :hot:
good luck!
Andy Bartha 20th August 2007 08:31 PM
From your picture it looks like you are right they are the same. Can you supply me the name of the manufacturer and an e-mail address. It would much easier to replace the ribbon than whole tweeter.
AKN 20th August 2007 08:43 PM
Gamma
HIFI KIT in here in Sweden has had Gamma units in stock since they opened the shop in the mid seventies.
Here's VLD13, expensive but available.
Maybe HIFIKIT have spare ribbons for sale?
[Ro]Sharky 20th August 2007 08:43 PM
sorry, i don't know who made them and neither their email address, if they have one and if they are still in bussiness.
I got them from a friend. They were 10$ a pair. :D
They sound pretty good.
Andy Bartha 20th August 2007 09:13 PM
4fun,
Could you do me a favor and get an e-mail address for HIFIKIT. I do not read Swedish and did not see an e-mil address. Those are the tweeters I have and they are the 16 ohm versions. I'm hoping they have replacement ribbons. Thank you for your help.
AKN 20th August 2007 09:40 PM
Originally posted by Andy Bartha
4fun,
I have the mailaddress.
I cannot see their mailaddress on their site, maybe HIFI KIT wants it that way. Strange but I suppose that I should not put it in public if HIFI KIT don't.
You have no PM buttom, mail me for the address.
Resources saved on this page: MySQL 18.75%
