| Planars & Exotics ESL's, planars, and alternative technologies |
Hello,
I am in the processs of refrubising my Quad ESL-57 electrostatic speakers. I have fitted new EHT boards and devices to them (plus corona lacquer due to HV), as the components on the old boards are not so hot anyway and degrade over 20 years! The treble panels look fine and also the bass. No arcing etc. But I am worried about the dust covers in particular. Have ordered new dust covers. Couple of things. Have noticed wrinkles on the treble panel dust covers though no holes and it ain't that bad being honest. May try a hair dryer first, then a heatgun after if needed. Have read the that the treble panal dust covers are the most important to get smooth otherwise yiou will get rattles at HF. One one of the ELS57's there is no dust covers for the bass panels!. So this needs sorted out asap. Have also noticed that around the rivets on the bass panel it looks like some leakage etc Almost like fluid. Wondering whether to use isoprop alcohol (IPA)to clean these up before fitting the dust covers. Any advice/help appreciatted! Kevin |
#2 |
Hi Fanuc,
I would post this query at the Planar section of www.audioasylum.com. There are some top Quad57 restorer experts there, especially kentaja and Sheldon Stokes. Regards, Wolf
Wolf |
#3 | |||
Thoroughly vacuum the panels and hook them up. Let them charge for a couple of hours and then carefully listen for strange noises like plops, hissing or ticking. If it's silent then you're probably in the clear. When you replace the dustcovers, don't tension them untill you have repositioned the panels in the frame. What materials did you order? |
#4 |
Hello,
Have attached an image of the back of the els57. What I am concerned about is there is no dust covers on the bass panels, but also look at the rivets. Doesn't appear to be bad corrosion but there is some leakage I suspect. Was wondering if IPA would clean this up. With new EHT boards being installed I guess there is some leakage from the diaphragm to the grounded rivets!. In the treble panel, the picture does not show the small ripples in the centre of the panel, but I may try a heatgun to smooth it off. Just start with low temperature at first. PS. there isn't any holes etc in the treble panel dust covers. Advice appreciatted. Kevin |
#5 |
Hello,
Have attached an image of the back of the els57. What I am concerned about is there is no dust covers on the bass panels, but also look at the rivets. Doesn't appear to be bad corrosion but there is some leakage I suspect. Was wondering if IPA would clean this up. With new EHT boards being installed I guess there is some leakage from the diaphragm to the grounded rivets!. In the treble panel, the picture does not show the small ripples in the centre of the panel, but I may try a heatgun to smooth it off. Just start with low temperature at first. PS. there isn't any holes etc in the treble panel dust covers. Advice appreciatted. |
#6 |
Hello,
#7 |
Hello
Reading your posts with interest contemplating delving into my own 57's at some point. Thought I'd bring to your attention that the image referenced in your previous post appears to have been inadvertently left off. Regards seraph |
#8 |
Hello,
#9 | |
Sorry about that. I am using an "erratic" wireless internet link at the moment (at least until tomorrow) and it kept bombing out when uploading the image. Just noticed there is a duplicate post also! :-) Kevin |
#10 |
What concerns me for people in the know about refurbing Quad ELS57's etc is the liquid like substance around the rivets on the bass panel, if you look closely.
Clean it off with Isoprop Alcohol ? and get the hoover out etc? In fact some people think the Quads sound better without the dust covers ( higher SPL I think? ) or more transparent sound etc. Though I have no opinion to offer on this personally and would prefer to put the dust covers back on. £32 for a kit (rolls) - apparently it could do 10 - 20 quads! |
| refurbing d200 soundstream amps. | guitarkirb | Car Audio | 5 | 31st October 2008 10:23 PM |
| Want advice on refurbing old speakers using RS 1354a s. | careless | Full Range | 1 | 3rd April 2008 05:42 PM |
| Refurbing old cabinets, FR style | Kensai | Full Range | 10 | 23rd October 2006 04:09 PM |
| refurbing orion 225hcca | Clipped | Car Audio | 3 | 3rd August 2005 06:58 AM |
| Crossover question (refurbing Yamaha PA cab) | los_gatos | Multi-Way | 5 | 4th January 2004 06:23 PM |
| Page generated in 0.12760 seconds (82.90% PHP - 17.10% MySQL) with 11 queries |
